Is your 13 section with the solid mount the same as the Yosh then? The Yosh is better than the YMS V8.Trafficjamz wrote:Oh yes there is a huge differenceeliteguy50 wrote:Such as?fastplastic wrote:umm there is a big difference.....![]()
That is the reason I want to find one of these 13 section pipes![]()
It took Fastplastics ride from mild to wild when paired with a 28mm carb![]()
At first glance these two pipes seem to be the same, but if you bring out the tape measure, you will see the are indeed different.
Checkin in, first post... here at least
Re: Checkin in, first post... here at least
- Trafficjamz
Yes exactly like the yosh, but with a solid mount. sections start up the head pipe sooner and grow to an overall larger diameter before the cone piece.eliteguy50 wrote: Is your 13 section with the solid mount the same as the Yosh then? The Yosh is better than the YMS V8.
Did you see my PM about that 2nd part # for the crank gasket? I could only find the first on bike bandit but the 2nd is ...?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
Chicago Ben wrote:Did you see my PM about that 2nd part # for the crank gasket? I could only find the first on bike bandit but the 2nd is ...?
I gave you the honda part #
you sure you typed that 2nd part # correct... I cannot find it on any parts website
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- Trafficjamz
here ya go
91201-GK8-003 OIL SEAL (15.6X23.5X7) (crank seal)
91202-GAH-721 OIL SEAL (19.4X31X7) (crank seal)
ordered off bikebandit , shipping to your front doorTrafficjamz wrote:here ya go
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Took a comparison shot if anyone was curious to see the Daytona shock next to the stocker. As you can see it is slightly longer.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
- KingJeff801
Nice shock. It must have costed a pretty penny being a daytona.
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Honda dealer is cheaper bikebandit shipping is nuts(to canada anyway)Chicago Ben wrote:ordered off bikebandit , shipping to your front doorTrafficjamz wrote:here ya go
PS3 it only does everything.
Actually I have been waiting for months for the color scheme to get back in stock at bowlsla.com. They carry them for $85. Not too bad since most even on ebay are that much...KingJeff801 wrote:Nice shock. It must have costed a pretty penny being a daytona.
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
I hear that, just when you live in downtown Chicago there aren't too many Honda motorcycle dealers close by...toad772 wrote:Honda dealer is cheaper bikebandit shipping is nuts(to canada anyway)Chicago Ben wrote:ordered off bikebandit , shipping to your front doorTrafficjamz wrote:here ya go
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Parts keep rolling in...
I have a used Met wheel on its way and a 90/90-10 Pirelli SL 26 tubeless to put on it
The money pit!
The money pit!
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Try 42 miles to the nearest Honda dealer and the next is 48 miles. I don't think your distance is an issue.Chicago Ben wrote:I hear that, just when you live in downtown Chicago there aren't too many Honda motorcycle dealers close by...
Those Pirelli SL 26's are excellent tire for the money......also Shinko has been performing top-notch on the front of my Gyro track bike considering they cost about $22 a piece......the guys I race with swear that Dunlop tt92's are the sh**.....they cost BIG $$......I'm not a fan of Cheng Shin or Kenda..........Chicago Ben wrote:
