Sym dd w/ hona dio engine i need help please!
Re: Sym dd w/ hona dio engine i need help please!
na i meant this 28mm
http://www.jiangwayne.com/scooter/p_i.php?i=59
would a 32mm not work properly on my setup?
That is the j pipe. I am talking about the 28mm sectional. A 32mm is too big for your setup.
ok so u meant this one then?
http://www.jiangwayne.com/scooter/p_i.php?i=61
would it be better than my tecnigas for top end?
No, that is an expansion chamber pipe. I am talking about the sectional v8. It looks just like the pipe in your ebay links except it is 1/8th smaller.
im going to try and fit a single wire adjustable throttle cable myself, can i do the part of connecting the cable to the carb before connecting the other end to the throttle?
it is easier to screw the cable into the throttle housing then thread it down the front and back to the carb
Fit my throttle cable and got about 70mph out of my scooter on some long, flat road!
how can i tell if my speedo cables broke completely? its randomly stopped working, it had came out at the speedo end but i put it back in n still nothin? if it is broken wheres the cheapest website to get one?
thanks
thanks
Sym DD
72cc Polini Corsa
Tecnigas Next R exhaust
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Koso variator w/9g rollers
Race clutch w/2000 rpm clutch springs
Bando racing belt
60+mph
72cc Polini Corsa
OKO 21mm carb
CT intake manifold
7.4:1 gearing
Bando racing belt
60+mph
* is tht any1 no whr to get a speedo cable for a sym dd cheap?
Go to your sym dealer I doubt there is an aftermarket one. Or get a used one from some wreckers!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
