Plus 1, ottoman. But rememberottoman wrote:Great advice... non street legal drag scooter... no licence... no registration... probably too loud and probably going faster than the speed limit... heck why would a cop even look twice.iceman77 wrote:SpreeMadness520 wrote:Still tuningpast three days the my neigbors have been calling the cops. Thankfully ive been in my driveway everytime they drive by
f*** The Po-lice
if you're not making to much noise after 10pm then do your thing bud.
TJ
Im sorry.. your right... heck with the neighbors just do what you want.
MONSTER Spree
Re: MONSTER Spree
Re: MONSTER Spree
Any pictures yet Spreemadness?
- SpreeMadness520
Re: MONSTER Spree
I know bear "young and stupid" Im going to have fun now because some day ill be too old to do this stuff.
Pics are on the way
I marked out an 1/8th mile out in the middle of no where near my friends house.
Atleast I have fans?
Pics are on the way
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
How old is too old? The only reason I can't do it now is because of disabling injuries from being stupid when younger. That is if 48 counts as younger, as it does for me.SpreeMadness520 wrote:I know bear "young and stupid" Im going to have fun now because some day ill be too old to do this stuff.
Pics are on the way
Atleast I have fans?![]()
- kingkamehameha
Re: MONSTER Spree
How big are your jets? Got any boost and intake port pics?SpreeMadness520 wrote:I know bear "young and stupid" Im going to have fun now because some day ill be too old to do this stuff.
Pics are on the way
Re: MONSTER Spree
Record some passes on the 1/8th mile, curious to see it.
Re: MONSTER Spree
"probably going faster than the speed limit"
Yeah or risk getting run over by everyone in a hurry going nowhere.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- kingkamehameha
Re: MONSTER Spree
Im with evilone on that. I refuse to ride a moped that only goes 35. They are death trapsevilone wrote:"probably going faster than the speed limit"
- Trafficjamz
Re: MONSTER Spree
Re: MONSTER Spree
lift that fuel line more so there isnt any sag in it. remember its a gravity feed style so any uphill the fuel has to travel the more pressure you need for it to flow faster. if not put a fuel pump. your best bet will be putting a fuel pump. the petcock outlet is to small anyways to keep up with the fuel flow the motor will use.it will start to lean out at wot after holding it for over 6sec. not alot but enough. thats might be why it seems lean on the main jet. mikuni fuel pumps sell for about $23 new. its the square one thats 14l per hr.need a case pulse for it to work right so tap the base of the manifold.
- kingkamehameha
Re: MONSTER Spree
Everyone on this forum should pp baka ten bucks for all the wisdom he bringsbakaracer wrote:lift that fuel line more so there isnt any sag in it. remember its a gravity feed style so any uphill the fuel has to travel the more pressure you need for it to flow faster. if not put a fuel pump. your best bet will be putting a fuel pump. the petcock outlet is to small anyways to keep up with the fuel flow the motor will use.it will start to lean out at wot after holding it for over 6sec. not alot but enough. thats might be why it seems lean on the main jet. mikuni fuel pumps sell for about $23 new. its the square one thats 14l per hr.need a case pulse for it to work right so tap the base of the manifold.
- SpreeMadness520
Re: MONSTER Spree
The fuel line sag is being addressed now
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
- Trafficjamz
Re: MONSTER Spree
SpreeMadness520 wrote:The fuel line sag is being addressed now
That is funny that when I mentioned it nothing was done.....but when baka says to fix the line, you jumped right on it.
Can I post some videos of 6th street drags.....or is that top secret info?
Re: MONSTER Spree
why did the rpm from take off for about 3-4sec stay some what low then it jumped up high? was he at full throttle from the start?
- Trafficjamz
Re: MONSTER Spree
bakaracer wrote:why did the rpm from take off for about 3-4sec stay some what low then it jumped up high? was he at full throttle from the start?
He does not have the pilot jet or needle clip set right yet.
Slowly rolling into the throttle is the only way to not have it stumble off the line i guess.
I also think the grab springs are set too low. Takes the fist 60 ft or so to get "on the pipe"
