Page 10 of 13
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 12:47 am
ottoman wrote:iceman77 wrote:SpreeMadness520 wrote:Still tuning
past three days the my neigbors have been calling the cops. Thankfully ive been in my driveway everytime they drive by
f*** The Po-lice
if you're not making to much noise after 10pm then do your thing bud.
TJ
Great advice... non street legal drag scooter... no licence... no registration... probably too loud and probably going faster than the speed limit... heck why would a cop even look twice.
Im sorry.. your right... heck with the neighbors just do what you want.
Plus 1, ottoman. But remember
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 1:39 am
by ragtop89
Any pictures yet Spreemadness?
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 4:38 pm
by SpreeMadness520
I know bear "young and stupid" Im going to have fun now because some day ill be too old to do this stuff.
Pics are on the way
I marked out an 1/8th mile out in the middle of no where near my friends house.
Atleast I have fans?
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 4:45 pm
SpreeMadness520 wrote:I know bear "young and stupid" Im going to have fun now because some day ill be too old to do this stuff.
Pics are on the way
How old is too old? The only reason I can't do it now is because of disabling injuries from being stupid when younger. That is if 48 counts as younger, as it does for me.
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 4:49 pm
by kingkamehameha
Pics are on the way
How big are your jets? Got any boost and intake port pics?
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 5:03 pm
by ragtop89
Record some passes on the 1/8th mile, curious to see it.
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 9:10 pm
by evilone
"probably going faster than the speed limit"
Yeah or risk getting run over by everyone in a hurry going nowhere.
Re: MONSTER Spree
Posted: Fri Mar 16, 2012 9:11 pm
by kingkamehameha
evilone wrote:"probably going faster than the speed limit"
Im with evilone on that. I refuse to ride a moped that only goes 35. They are death traps
Re: MONSTER Spree
Posted: Sun Mar 18, 2012 11:40 pm
by Trafficjamz
click pic for video
Nice job Drew
Re: MONSTER Spree
Posted: Mon Mar 19, 2012 12:02 am
by bakaracer
lift that fuel line more so there isnt any sag in it. remember its a gravity feed style so any uphill the fuel has to travel the more pressure you need for it to flow faster. if not put a fuel pump. your best bet will be putting a fuel pump. the petcock outlet is to small anyways to keep up with the fuel flow the motor will use.it will start to lean out at wot after holding it for over 6sec. not alot but enough. thats might be why it seems lean on the main jet. mikuni fuel pumps sell for about $23 new. its the square one thats 14l per hr.need a case pulse for it to work right so tap the base of the manifold.
Re: MONSTER Spree
Posted: Tue Mar 20, 2012 6:46 pm
by kingkamehameha
bakaracer wrote:lift that fuel line more so there isnt any sag in it. remember its a gravity feed style so any uphill the fuel has to travel the more pressure you need for it to flow faster. if not put a fuel pump. your best bet will be putting a fuel pump. the petcock outlet is to small anyways to keep up with the fuel flow the motor will use.it will start to lean out at wot after holding it for over 6sec. not alot but enough. thats might be why it seems lean on the main jet. mikuni fuel pumps sell for about $23 new. its the square one thats 14l per hr.need a case pulse for it to work right so tap the base of the manifold.
Everyone on this forum should pp baka ten bucks for all the wisdom he brings
Re: MONSTER Spree
Posted: Thu Mar 22, 2012 4:23 pm
by SpreeMadness520
The fuel line sag is being addressed now
Re: MONSTER Spree
Posted: Thu Mar 22, 2012 10:37 pm
by Trafficjamz
SpreeMadness520 wrote:The fuel line sag is being addressed now
That is funny that when I mentioned it nothing was done.....but when baka says to fix the line, you jumped right on it.
Can I post some videos of 6th street drags.....or is that top secret info?
Re: MONSTER Spree
Posted: Thu Mar 22, 2012 10:49 pm
by bakaracer
why did the rpm from take off for about 3-4sec stay some what low then it jumped up high? was he at full throttle from the start?
Re: MONSTER Spree
Posted: Thu Mar 22, 2012 10:54 pm
by Trafficjamz
bakaracer wrote:why did the rpm from take off for about 3-4sec stay some what low then it jumped up high? was he at full throttle from the start?
He does not have the pilot jet or needle clip set right yet.
Slowly rolling into the throttle is the only way to not have it stumble off the line i guess.
I also think the grab springs are set too low. Takes the fist 60 ft or so to get "on the pipe"
