Page 10 of 12
Re: soft seize?
Posted: Tue Feb 28, 2012 9:53 pm
by swimmingfree
dingle berries?????
Re: soft seize?
Posted: Tue Feb 28, 2012 9:57 pm
by iceman77
swimmingfree wrote:dingle berries?????
sure why not. :lol:
Re: soft seize?
Posted: Tue Feb 28, 2012 9:58 pm
by iceman77
maybe my bike would run better on the clear water.
Re: soft seize?
Posted: Tue Feb 28, 2012 11:38 pm
by Trafficjamz
You said the plug was dry...
Try putting a little premix right in the spark plug hole and see if it fires.
The clicking you heard to day was just your starter relay...cause your battery is dying :sad:
Re: soft seize?
Posted: Wed Feb 29, 2012 7:59 am
by iceman77
Trafficjamz wrote:You said the plug was dry...
i had jumper cables on it that's why i thought it was weird.
TJ
Re: soft seize?
Posted: Wed Feb 29, 2012 8:08 am
by swimmingfree
starter dont last for ever ... thay get hot and die ..
what the gap on the plug ????
Re: soft seize?
Posted: Wed Feb 29, 2012 8:14 am
by iceman77
swimmingfree wrote:starter dont last for ever ... thay get hot and die ..
brand new plug. wouldn't the gap be correct?
TJ
Re: soft seize?
Posted: Wed Feb 29, 2012 8:20 am
by swimmingfree
spark plug gap set it to the minamum by the book..
Re: soft seize?
Posted: Wed Feb 29, 2012 11:31 am
by iceman77
checked the gap it is at .024
TJ
Re: soft seize?
Posted: Wed Feb 29, 2012 11:33 am
by Mystic
the plugs come pregapped, try trafficjamz suggestion, splash a little premix in the sparkplug hole and try starting it sometimes it needs a little help after installation of new parts
Re: soft seize?
Posted: Wed Feb 29, 2012 11:41 am
by bakaracer
Mystic wrote:the plugs come pregapped, try trafficjamz suggestion, splash a little premix in the sparkplug hole and try starting it sometimes it needs a little help after installation of new parts
Never assume the plug is pre gapped to spec. What if the box got dropped. It could change the gap.always check it before install. There are other motors that use these plugs that have different gap specs.
Re: soft seize?
Posted: Wed Feb 29, 2012 11:43 am
by iceman77
ok i have my laptop w/ me beside my bike...
i tried putting some premixe in the plug hole. still nothing.
TJ
Re: soft seize?
Posted: Wed Feb 29, 2012 11:44 am
by iceman77
Mystic wrote:Never assume the plug is pre gapped to spec. What if the box got dropped. It could change the gap.always check it before install. There are other motors that use these plugs that have different gap specs.
plug gap is .024 i checked it.
TJ
Re: soft seize?
Posted: Wed Feb 29, 2012 11:48 am
by swimmingfree
do you get a sputter out of it????
did you take off the fly wheel??
Re: soft seize?
Posted: Wed Feb 29, 2012 11:58 am
by bakaracer
TJ
So then that's sounds like your having a spark issue. Either timing is off or the spark is weak. Check connections to the coil and clean the terminal. Check tthe coil wire to plug cap. Unscrew the cap and check to see if the wire is burnt. If it is then cutoff the burnt end and screw the cap back on. Also check the green gound wire from the stator that bolts where the starter is. Make sure the bolt is tight or if the wire is not cut. Check the fuse where the battery is at too. Just try to eliminate stuff that might cause it not to have spark. Make sure the spark is strong at every arc. If its strong then soft then strong or just stays soft on the spark then that's why its not starting.
