Modification of NQ50 1986 Honda Spree
frog357
Post by frog357 »
I used fine sandpaper to give a texture for the paint to stick. It seems to work great but I had black dust in my lungs for a few weeks after that.
FreddyT
vette76
Post by vette76 »
i used that fusion paint and it seems to work well.after i cleaned that front panel with acetone the paint finally stuck. the only problem with that paint is it is real wattery and runny.if you take your time it works well. i will try to get pics when it is finished, but im not sure how to get them here.
Jerry
Post by Jerry »
My guess is some kind of silicon like Armor All. There are compounds that will remove all traces of it. I paint autos quite a bit and silicon is one of those things that NOTHING sticks to. Auto paint thinner works for me.
Scoot safely
They make a special plastic paint prep, sold at auto paint shops. I always use this stuff for prep work. Thinner works OK on steel, but will melt the factory finish on the SMC spree parts.
vette76
Post by vette76 »
i had some car paint lying around and i was gonna use that but then i found this paint and im happy i went this route. it looks awsome. plus i think car paint will melt plastic.
Kikwear
Post by Kikwear »
Did adding a stereo place a stressful burden on your electrical system? This bike seems so fragile that it can run the bike and that's about it. What is the draw from a car stereo?
vette76
Post by vette76 »
it works well but i suggest a new batt.
Kikwear
Post by Kikwear »
Already got a new sealed battery.
vette76
Post by vette76 »
it will work. i suggest it is not the top of the line.if it gets wet its screwed.
Kikwear
Post by Kikwear »
Can you post or email some pics?
BluPhire
Post by BluPhire »
Can you run the CD player off of a dead battery, beacuse of the alternator? Just wonderin' because I cant afford a new battery, yet alone a new belt, mine just broke and now I'm stranded. I went from :D to :) to :( to :cry: . lol. Not really lol. I'm SOL.
I try to fix things with a hammer and wrench!
vette76
Post by vette76 »
u cant use a dead batt because the alt only charges at a certain speed. my advice is wire it into the headlight. the only problem with that is after u shut the bike off u lose all of ur pre-sets
BluPhire
Post by BluPhire »
Oh, d***, I guess I won't be putting a "Stereo" on any thime soon.
Kikwear
Post by Kikwear »
Not true with the presets. Stereos have two power leads, ignition and battery. Run the ignition off the yellow headlight wire and the little amount of battery left should be enough to retain the presets.
Tippmann98
Post by Tippmann98 »
usually presets are stored with 2 AA batteries.
