hot taiwan setup (Arnadanoob)
Moderator: FAQ Moderator
Re: hot taiwan setup (Arnadanoob)
26keihin carb rocks you will love its performance and longevity
- burnt_toast
28oko is *, and perfect if you like to be LOUDlosthope wrote:So what size carb would you put on a polini corsa?Arnadanoob wrote:Bakaracer is right on the money. Ideally 24mm carbs will work better in the end. If there's anything anyone here is going to learn from being here, take this one home. Sometimes in order for the engine to produce more responsive power, you need to go smaller on the carb. There's a lot more people miscalculating the need for carburetion that it's very common to find folks that over carb their bikes.
26mm should be good too for optimal flow
projects galore
On a stock Corsa, ideally you want to be between 20mm-24mm in carb size for absolute top performance, however finding carbs in that range isn't always easy. In Hawaii alot of guys go with a 28mm, not because it's better than a 24mm (all it does is drink more gas and make more noise) but due to price, the 24mm is very close if not the same price as the 28mm.
Reliable and dependable tuning from 15+ years of experience.
you could go for a polini/fabrezzi 82cc all alluminium bore with crank costs big bucks also a 25mm polini low profile carb+intake works great...
check my site for parts
http://sleepyscooters.yolasite.com/
i will be putting up 10 different parts this thursday when i get them in
anything 82cc or smaller 18-24mm carb.mini stroke crank with 72cc-82cc bore 24-28mm carb any bore and crank larger use 28-33mm carb.it depends what your setup is and how you port your cylinder too.losthope wrote:So what size carb would you put on a polini corsa?Arnadanoob wrote:Bakaracer is right on the money. Ideally 24mm carbs will work better in the end. If there's anything anyone here is going to learn from being here, take this one home. Sometimes in order for the engine to produce more responsive power, you need to go smaller on the carb. There's a lot more people miscalculating the need for carburetion that it's very common to find folks that over carb their bikes.
thats only for you local boyz
pg long is the best pipe to run.
