My Fun Experience Courtesy of a Stuck WOT on my Spree
Re: My Fun Experience Courtesy of a Stuck WOT on my Spree
Post by Kenny_McCormic »
Lunytune wrote: Kenny,
I learned the meaning of serious prayer commuting 45 miles through the winter at 5am for a dozen years, and I don't mean the hypocritical type that only calls on God in a crisis. When you top a hill at 40 and are doing 70+ on ice by the time you hit the bottom (don't touch the brakes), you better have something more than an ace up your sleeve.
That's what the 4x4 with studded snow tires is for!
jguy
Post by jguy »
I can't remember if I read this perfect mathematical formula here or on Moped Army:
MY SCOOTER (OR MOPED) + MY BEST FRIEND = BAD IDEA
'86 Spree
'80 Motobecane 50V
Just Ride
Lunytune
Post by Lunytune »
Yeah Well. I remember one time on the way home from work, I guy in jacked up 4x4 SUV with off road tires passing me on Interstate in a strong storm. I was doing maybe 30, he passed me doing about 45, got 200 yards in front of me and went into a spin which put him in the medium. I smiled at him as I drove by.
Even the best equipment isn't worth jack s*** if you dunno how to use it.
Lunytune
Post by Lunytune »
Kenny_McCormic wrote:Even the best equipment isn't worth jack s*** if you dunno how to use it.
Translated, that means respect your equipment and respect the conditions. When I was on the icey roads, my job demanded that I be there, but I always started out a hour early to deal with conditions
That also means take your equipment on a frozen lake, learn what it takes to spin it out and what it takes to make it go straight again. Also learn that driving in slick s*** is a 2 hand 100% concentration required deal.
Post by eliteguy50 »
It means read the entire post
offroad/snow tires don't do jack, it is the cleat effect that the studs have
gspreesea
Post by gspreesea »
You guys are awesome, thanks! Im still laughing about it.
As an update: I found out what made it stick. The little plastic tab in the throttle slide "chamber" was worn completely down. I took a tiny punch and tapped at it from the outside of the carb, it came out just enough to let the slide start lining up again with it. My first scooter, what can I say.
Videonut
Post by Videonut »
gspreesea wrote:You guys are awesome, thanks! Im still laughing about it.
you can say good job and wave at all the other scooter riders out there. welcome to the clan
Videonut
gspreesea wrote:As an update: I found out what made it stick. The little plastic tab in the throttle slide "chamber" was worn completely down.
The alignment pin that is built into the carb on the inside?
Lunytune
Post by Lunytune »
That's plastic? :?:
Lunytune wrote:That's plastic? :?:
that was my thought, I have seen it in plastic but that is rare, typically it is a brass pin.
