What type of oil to use?
Re: What type of oil to use?
hondaman wrote:Better get better glasses there Bear. I never said only Honda brews the correct oil. I have always stated to NOT use 2 cycle oil made for Chainsaws,Boat motors, Weed Whackers etc. which would be a pre-mix oil. Only use oil stated for Injection type systems. Not just any type 2 cycle oil will do. You have to read the label. Yes your engine will run with the other type oil but it is not good for it, and will cause excess carbon buildup on the piston and exhaust port. Did you ever hear of decarbonizing the cylinder head and piston? Using the wrong type of oil will increase the severity of this carbon and in turn cause engine trouble or failure.
I will buy the boat motor oil because marine engines run cooler than air cooled engines and their oil is rated TCW-I, II, III or IV, but chainsaws and weed eater are air cooled, in fact they run hotter than the scooters because of poorer air flow over the engine, also usually chainsaws and weed eaters are not oil injected. But I wonder why so many of you guys think that an oil can only be formulated to be either premixed or injected? When in fact, all injected oils work just fine as premix and in most cases regular 2 stroke oils will work fine in injected engines.
wiguy05
Post by wiguy05 »
I use this.
I like it. That is all.
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
wiguy05 wrote:I use this.
Nothing wrong with Amsoil. However, I never ran it at the ratios they said though. I used the same mix as everybody elses oil.
Spreetard
Post by Spreetard »
Amsoil smells like * :roll: i hate riding behind people that run it.
other than that, it's great.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Amsoil smells like * :roll: i ate riding behind people that run it.
It smells the way it does because it is a synthetic and has no dino oil in it.
Post by Kenny_McCormic »
You need a 2 stroke injector oil designed for air cooled engines.
Kenny_McCormic wrote:You need a 2 stroke injector oil designed for air cooled engines.
Ande almost all 2 stroke oils produced today fit that definition.
wiguy05
Post by wiguy05 »
Spreetard wrote: Amsoil smells like * :roll: i hate riding behind people that run it.
Maybe you should upgrade from that Spree and you'd be ahead of everyone else :P
Sorry, had to.
2006 Sachs Madass
- FTP 140cc Kit
- Lifan 90cc auto
Spreetard
Post by Spreetard »
Sorry, had to.
:mrgreen: sick burn. wait 'till i can afford to build my dream dio swap.... :twisted:
Ol' Red
Broken...
Spreeio
1987 Spree
surfnturf
Post by surfnturf »
I've been having good luck so far with Repsol Synthetic blend at 32:1. Pretty cheap at 8 bucks for a liter and a half (I think) too.
SpyderMike
Post by SpyderMike »
so far ive been using hondas very own GN2...just picked up a whole case of it for $42 :twisted:
CamTastic
Post by CamTastic »
This topic should be closed. Everyone's Responce's here would work but some better than others it's the riders choice on what he uses but the suggestions point him in the right direction.. Plus the topic was "What type of oil to use?" Not What are you oponions on Oil brands and makes... Just answer the question at hand and be done with it... And move to the next person who needs help. :mrgreen:
Best Regards, Cameron. Have a good day! :o
- 1986 Honda Spree Nq50.
CamTastic wrote:This topic should be closed. Everyone's Responce's here would work but some better than others it's the riders choice on what he uses but the suggestions point him in the right direction.. Plus the topic was "What type of oil to use?" Not What are you oponions on Oil brands and makes... Just answer the question at hand and be done with it... And move to the next person who needs help. :mrgreen:
Image A total of 11 post and you are now an expert on what should be done about oil. :roll:
CamTastic
Post by CamTastic »
Hey now i was just giving advice and for one just because someone don't have alot of post's don't mean they don't know a thing or two i ment nothing by my post i was just basicly saying the thread has been answered
Geez, don't be so sensitive. I was just harassing the noobee. but I should have included at least this Image or this Image. My fault for omitting them.
