As there is a fair amount of plastic missing, usually the brackets where they attach to the frame or each other i had to make several brackets. This is the bracket i made to hold on the rear fender, it was held on by tie wraps when i got the scoot, not sure if tie wraps would pass inspection.
Note the use of aluminum to keep the weight down. Ok Ok i had some aluminum lying around.
The final problem i had was the mirrors. I bought OEM mirrors as i only had 1 ratty looking one on the scoot when i got it and well they were cheaper than after market ones. Only trouble was that someone had drilled out the and re tapped where the mirrors screwed in. After some thought i decided that a nut on top and underneath the brackets that hold the mirrors on would work. only trouble was i didn't have enough thread on the mirrors to fin do so with the nuts i have. So once again i got out my handy dandy angle grinder. By screwing 2 nuts on to the end of a bolt with the second one only half on i could grind down a nut to about 1/4 the width giving me enough room to thread them on the mirror stalks and still bolt the mirrors onto the brackets.
And now the scoot is all done, my bro loaded it up and took it away
Merry Xmas Eden!
