yah any mufflers I make will be later. Late next year. I want to get 47mm kits made first. the modified exhaust. Any ideas on braking modification on a spree that goes 55+?????? Maybe a parachute... hehe I will have to label the 47mm kit as a racing kit. Not for street use...
Marc
44mm spree kits are proven!!
- tazland001
Re: 44mm spree kits are proven!!
bradthreee wrote:I think Jstone has one of noiseguys' "highway" pipes, which he lent to Taz with hope of mass producing it. Im not sure tho I just might beBear45-70 wrote:jstone wrote:Any info on the tuned pipes for the spree? I'm about to get mine running again as soon as I get a motor and would like my pipe back if you can.
A true tuned aftermarket pipe is non-existant at this time. Hopefully in the near future someone will do so.
Correct. Hoping to get it back sometime, hopefully before "late next year".
To Go Faster, First Install Better Brakes
Taz axt:
Is it possible that the 95mm brake panel might fit inside a Spree's gossamer forkage? If so, a front wheel assembly from a 1994-later Elite might answer your braking concerns. Improve braking from Totally Terrible to Merely Mediocre. Otherwise, a disc-equipped front end might be the ticket to preventing a Spree-shaped dent in the side of that Avalon.
Taz axt:
That's a very good question to be sure. However I do not believe it will need an answer until you wright a pipe that will go along with your proposed 47mm kit. The Spree exhaust simply won't support the RPM you would need to achieve that speed gears or not.Any ideas on braking modification on a spree that goes 55+??????
- tazland001
I was thinking weight might be a factor as well when braking. Is this true? Disk brakes for the front could work but who would want to spend the money.. I was thinking more like a cynder block and rope might work.. just kidding......
Marc
Marc
To be fully effective,
brakes have to stop the bike and the rider. Sprees are 30-40 pounds lighter than Elites, but add the weight of a 180-pound rider and you're hauling down 270 instead of 300, an insignificant difference. Speed's the thing, and that whole "square of velocity" thing means brakes have to grow disproportionately bigger as you go faster.
Cinder blocks work well if you're riding soft surfaces. For pavement, tie one end of a stout rope to your luggage rack. The other end you tie to this:
http://www.cabelas.com/cabelas/en/templ ... hasJS=true
Lash the anchor over the coiled rope using a Velcro (Tm-R) tie-down. Flip it off when that Camry turns across your path.
Seriously, I have some misgivings about that tiny front drum stopping more than once from 50. Does the slightly-less-tiny 95mm drum panel even fit?
- tazland001
Thats funny... i dont know of any honda scooter fork system that would work on the spree with disk brakes. the AF24 is the earliest model scooter I ever saw with disk brakes from honda. Braking will have to be an issue. There has to be a solution down the road.
