idles then boggs with throttle
Clivester
Re: idles then boggs with throttle
Post by Clivester »
kygreen229 wrote:ya pretty much impossible to hold a nut on the back and tighten it. so i would like to tap it..drill out the manifold(motor side) and the plastic flange that goes between the carb and manifold..then tap the carb to 1/4x20..the part im confused about is you can use a 1.5 or 2 inch bolt in the tapped hole? just which ever? thanks. just dont want to mess this up :smile:
Check out keyserts
http://www.newmantools.com/key.htm
They lock in place and will allow you to re-thread to the original size, if there's enough meat around the original thread (don't have carb in front of me to check though).
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
aerorob
Post by aerorob »
try what wheelman said about the brass tube to the left of the main jet in your carb. your symptoms are identical to what mine where... it would idle then when i try to give it any throttle it boggs. soak or carb clean it and use compressed air on it and you should be up and running again.
