No power until about 20mph... then no problems
mr pibbs
Re: No power until about 20mph... then no problems
Post by mr pibbs »
razzamatazm wrote:haha... whoops, I mean my kickSTARTER not stand... haha- I can imagine this being a lot more difficult without that...
I'll try the ratchet trick
Right, right. I was a little surprised when you said that.
The first time i took mine off, it was probably the first time it had come off in a decade or so, i'm sure. Took a little love.
If you have a brass hammer, could help loosen it with some light rapping.
1993 Elite - The Mad Max
evilone
Post by evilone »
You can leave kickstart lever on. Cover does go over 2 "locating pins" and might just be snug on them locating pins.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
razzamatazm
Post by razzamatazm »
OK! Got the clutch off, but I'm having issues getting the bolt off the gear connected to the engine... I can't turn it without turning the engine... Do I even need to get back there to check the roller bearings? I'm about to run up to autozone to get a bigger socket wrench for the 39mm socket, and then I'm not sure what I'm looking for in terms of damage... will it be obvious?
Once again, I appreciate you guys helpin a noob :)
1994 Elite50S w/ sport pulley/clutch, drilled airbox, drilled exhaust, bigger fuel jet... 45mph
razzamatazm
Hey there, I'm attaching some pictures of the clutch. I'm unable to get the 39mm nut off... Can you tell me if there is anything obviously wrong here?
Thanks!
evilone
Post by evilone »
The clutch pads look contaminated or got too hot and are now burnt/glazed which neither one is good. Could just be the picture? Can you use a screwdriver to pivot each arm out to make sure they are moving smoothly? How does your clutch bell look? Does it look like it got too hot? I put the 39mm nut in a vise and turn assembly with big channel locks to loosen it then set it on the ground with 1 knee and 1 hand on it and remove the nut the rest of the way by hand.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
razzamatazm
They do move with a screwdriver, however I wouldn't say it's easy... but that may be do to the spring tension. I don't have a vice on hand so I may need to go to a shop somewhere. I'm attaching some pictures of the bell, there is some material in there that looks like rubber or oil gunk? Finally, I bought a belt recommended on these forums, the Gates 7240, however it's not as wide as the old belt. Will this be a problem?
Thanks again.
photo 4.jpg (90.87 KiB) Viewed 6408 times
photo 3.jpg (90.46 KiB) Viewed 6408 times
photo 2.jpg (127.86 KiB) Viewed 6408 times
razzamatazm
I also noticed that there is quite a bit of black (sortof powderish / greasy) stuff inside the case. I'm not sure if this stuff just builds up over time or what but could this have contributed to the problem?
mr pibbs
Post by mr pibbs »
razzamatazm wrote:I also noticed that there is quite a bit of black (sortof powderish / greasy) stuff inside the case. I'm not sure if this stuff just builds up over time or what but could this have contributed to the problem?
That is probably dust from your belt and/or clutch pads.
The pads look just fine, as does the build up in the bell. Get some simple green and clean bell and gently make sure pads are clean of dust. Don't get grease on the pads - it is a tough problem to fix.
razzamatazm
So once I clean the pads and the bell, should it run normally? Is that the problem? Also, if you know anything about the belt width I'd appreciate your insight.
Also- Is anyone here from LA - a set of seasoned eyes would do untold wonders... I'm trying but it's difficult with the basic understanding that I have.
Thanks again.
novs86
Post by novs86 »
I disagree,
The bell is blue which is a sign to change it out. I would purchase a whole new clutch rather than using what you have. Those pads look burnt from overheating.
This is why there is no power to 20mph. It's taking that clutch to long to engage because its wore out.
I'd rather be riding my Aero!
razzamatazm
Any ideas as to how this could have happened? I have a little over 4000 miles on the scoot. Also, does anyone know where I can get a full clutch assembly?
novs86
Post by novs86 »
Stock units are available from time to time on Ebay or post a WTB on this forum to see if anyone has one. If not here is another option.
http://cgi.ebay.com/ebaymotors/HONDA-EL ... 45ef20d211
evilone
Post by evilone »
That's why i asked about bell, yes it was overheated. Been there done that. Not sure of cause and you might find used parts or you'll have to get from dealer. Post a "wanted" in for sale/wanted.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
mr pibbs
Post by mr pibbs »
How would blueness on the bell effect the pads grabbing?
novs86
Post by novs86 »
mr pibbs wrote:How would blueness on the bell effect the pads grabbing?
A blue color is present when the bell has heated up and changed the strength of the metal . This is a good indication that the coating on the inside of the bell is no longer effective. New pads will not work well with a worn bell.
All clutch manufactures recommend replacement when this occurs.
