newbie spree tune up 1985 spree
How'd you break it?
fenderworks
Post by fenderworks »
just being stupid
just inserted the by starter a little too hard, the little black plastic piece that holds the needle on snapped..........$60.00 there has to be a cheaper way. still looking for a used one
steve :(
turn it up!!
fenderworks
got the bystarter today
got the new bystarter today. bike runs great!!! well for 50cc's anyway....
started tuning carb.. started at 1 7/8 out...but it was always cutting out on top end just dying for fuel so here is what i did
air screw out about 1/2 turn, then idle set so rear wheel doesnt roll.....that seems to be about right... pretty good low end, not so good midrange, and about 28 mph......ANY SUGGESTIONS???
i live in denver metro area about 5800 ft elevation
is there anyway to get more take off speed?, i kind of use the flinstone method of starting out from dead stop....use my feet for the first 5 mph
BY THE WAY
none of this work would have been possible with out the help of this FORUM............THANKS TO EVERYBODY!!
thanks
fenderworks
:D :)
turn it up!!
deathwish
Post by deathwish »
well u could reverse the pully mod by putting washers in the front pulley to run a lower gear ratio but u will loose some on top end :?
I have shortend my coil wire and midrange is alot better.... you could also gte stiffer clutch springs which i heard helps out alot but i have not foun any yet....... hope this helps :)
Wanna kno how to keep an idiot busy for hours look below
Wanna kno how to keep an idiot busy for hours look above
Check your main jet, stock is either a #65 or 68. Bump up a few sizes (65 -> 68 or 68 -> 70.) You are probably running a bit lean. Also check the needle setting in the slide, should be set to stock.
