Page 2 of 2
Re: can't get the throttle cable/main needle re-installed proper
Posted: Mon May 17, 2010 6:42 pm
by Rowbear
now that there is more oil in it, the light flickers and goes out when taking off so maybe if I fill it up it will stay out. I'll check the float and see if I can make the light go out manually, on some other date, I'm through with sprees for the day.
Posted: Mon May 17, 2010 7:30 pm
by Rowbear
I am having a tough time getting the idle set, if I set it when it's warmed up then it's too low to start the spree when it's cold and if I set it when the spree is cold it's too fast and spins the rear wheel like mad when it's on its stand.
