It isn't that ease. The Spree has a small crankshaft end. Too small to work with any existing variator. It takes engineering and then money to make a prototype, test it and them make changes then more money to have then produced.oldrock wrote:ok so where do we find prices and descriptions of these aftermarket parts? Oh and any update on a cvt drop in for the spree? Seems like if someone would just come up with an easy to install cvt upgrade for the spree, most of our concerns would be solved. Beter low end acceleration and better top end with one upgrade.
84-86 Spree, How do I get more speed?
Re: 84-86 Spree, How do I get more speed?
PimpinSpree
Mirage wrote:How do i get more speed?
Everything is stock.
How do you get any stock honda to go fast? Lots and lots of red or blue split loom
And don't forget stickers. Vinyl adds powerPimpinSpree wrote:Mirage wrote:How do i get more speed?
My spree only went 28mph before i put my NGK stickers on it...
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
I'd sure like to learn more about the 87 spree that does 42mph in your sig
I have my 2.8" tall tires on order but don't think that will get me where I'd eventually like to be with my spree. How did you get 42mph on yours? I have air grinders and a flex shaft dremel so might break down and start doing some port and polish on mine if I have to. A drop in CVT would be nice but if that is not in the cards with the spree, I guess it is time to start thinking about how to improve flow on the engine.
1985 spree 49cc offsets my
1969 mustang w/390 big block
- fightingplankton
i can support this. when i got my spree it didnt run at all. the first thing i did was add a silver surfer sticker to the front, now it goes 33-35mphSpreetard wrote:
(i also cleaned the carb and bought a new spark plug)
so if you do the math
stock=0mph
sticker=33mph
thats a 300% increase in speed
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
its the stickers I've been missing... dang why didn't I think of that earlier
If I throw some of my left over hotrod stickers like holley, edelbrock, accel, etc... maybe I can do 40 with my stock spree
- fightingplankton
you need a bumper sticker that says "my other ride is also a porche"
'86 spree
'86 aero50
'83 aero80
'86 aero50
'83 aero80
- martynkim
CHROME ADDS POWER!!!
And racing stripes add 5 mph to the top end.
- Trafficjamz
Dont forget about the vtec tuning badge. 10 mph boost easy
Ok enuff of all that stickes and chrome
Yes yes yes it is al about flow.
Spreetard's spree has a stock 41mm piston with over 8888 miles on it
but his jug, intake,case, and exhaust have all been ported to increase flow.
His top speed of 42mph came with the sacrafice of intial take off.
with the 42mph set up, you need to push with your feet a litte bit to even get going.
It is easy to change the pulley back, and gain some low end back.
His pully mod is shimmed in with thin washers, so all you have to do is move a washer or to.
Search ancient chinnese secrect on this frourm too see how we got it to take off fast AND have 40 mph top speed.
Took the words right out of my mouth.oldrock wrote:I'd sure like to learn more about the 87 spree that does 42mph in your sig![]()
Searching "Ancient Chinese Secret" nets you nothing worth learning the Ancient Chinese secret.
- Trafficjamz
here ya goBear45-70 wrote:Searching "Ancient Chinese Secret" nets you nothing worth learning the Ancient Chinese secret.
http://www.hondaspree.net/phpBB3/viewto ... =8&t=14539
i wouldn't call it "fast", and there is no case porting yet. other than that, what he saidTrafficjamz wrote:Dont forget about the vtec tuning badge. 10 mph boost easy![]()
Ok enuff of all that stickes and chrome![]()
Spreetard's spree has a stock 41mm piston with over 8888 miles on it![]()
i'm betting i can squeeze out a few more mph yet...
some rainy day i'll tear it down and take pictures, wait till you see how big my intake is...
Ol' Red
Broken...
Spreeio
1987 Spree
Broken...
Spreeio
1987 Spree
I'm not close to 40mph with my 85 spree yet but I did go from 28mph to 33mph by swapping out the tires for some IRC ones that are a little under 3" tall instead of the stock 2.5" ones. The cool thing is because the new tires have a tread pattern that has alot less rolling resistance, I can't really notice much difference in the bottom end. Maybe takes a second more to get up to 10mph but then revs right on up. I weigh 192lb and it pushes me 33mph on level ground. My son weighs 165 and he can do 34-35mph on level ground. I will be looking into some flow improvements soon but right now I am just enjoying riding it with the better top speed. At 33mph I can drive along with the flow of traffic on your typical 35mph streets. Only time I feel a little uneasy is on 45mph streets where cars still fly by. I am thinking I should be able to get it up to 35mph with a few small tweaks to flow on the intake and exhaust side. Just need to learn a bit more about them before I break out the grinders.
