Taiwan Exhausts / Mufflers to Ponder Over
detonatortuning
Re: Taiwan Exhausts / Mufflers to Ponder Over
Post by detonatortuning »
so, sum-azn-kid says the scorpion is real loud, i've found pipe sound levels to be very subject myself, any one have a vid with this pipe in use ?
wheelman-111 how loud is that "hot surface" pipe ? is that or something VERY similar to it readily available ?
i'm looking for a pipe that will heavily boost the off idle to 8-9k rpm range.
thanks,
steve
The Hot Surface pipe is a bit louder than stock, comparable to the intake noise of an open Pod. Much quieter than the PG and the Chamber pipes with muffler add-ons I've owned. Taz sold me mine, might have more. It's very good on the low end, seems to rev out to about 8-9K.
nacree
Post by nacree »
Taz what say you? Can you give us some more details on this pipe?
Thanks,
Nathan
Epschoenly
Post by Epschoenly »
Would be interested in more info on buying one of these hot surfaces jawns.
detonatortuning
yes, seems to be a common interest, though Taz seems to be keeping quite about the whole thing. too bad, i'd be in for sure.
steve
Munstah666
Post by Munstah666 »
If you're building a BB non stroker, I would use #2, V8 copy. But if you want the best, Scorpion is second to none if tuned right and not as loud.
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
Post by eliteguy50 »
Munstah666 wrote:If you're building a BB non stroker, I would use #2, V8 copy. But if you want the best, Scorpion is second to none if tuned right and not as loud.
Why a v8 copy? Why not just get an actual v8?
Munstah666
I was merely referring to which ones in HIS LIST (pg 1) I would use, but if you ask me LOOK at the second part of my qoute. ^^^
Munstah666 wrote:... I was merely referring to which ones in HIS LIST (pg 1) I would use...
Oh, I wasn't sure if one had better welds or metal or what.
