Page 2 of 3
Re: 86 honda aero again!
Posted: Wed Jul 07, 2010 7:51 pm
by caito
Posted: Wed Jul 07, 2010 8:36 pm
Looking at the picture, it appears the rack grounds to the frame and the light assembly grounds to the rack. So the ground in the harness maybe because that harness is also used in another application that requires it. As long as the lights work, don't swear it, but you need to mount the rack back to the frame (or at least run a jumper wire between the frame and the rack to test it) to actually tell if the short is gone.
Posted: Wed Jul 07, 2010 8:59 pm
by caito
that's just the thing. the lights still don't work. at all.
Posted: Wed Jul 07, 2010 9:04 pm
by martynkim
Hmmm..... did you check the leads with a test light? power in?
Posted: Wed Jul 07, 2010 9:14 pm
caito wrote:that's just the thing. the lights still don't work. at all.
They won't the way they are sitting in the picture, even if everything is good. You have to make the ground circuit by either bolting the rack to the frame of running a jumper wire between them. If they don't work then check the socket and the light itself.
Posted: Wed Jul 07, 2010 9:36 pm
by odinxxix
the rack looks broke where it would bolt by the seat. but in any event green is your ground. try hooking the green wire from the lights to that wire you said you seen hanging down. see if they work that way
Posted: Wed Jul 07, 2010 9:43 pm
by martynkim
Bear45-70 wrote:caito wrote:that's just the thing. the lights still don't work. at all.
Agreed, just saying check and see if power is coming in.
odinxxix wrote:the rack looks broke where it would bolt by the seat. but in any event green is your ground. try hooking the green wire from the lights to that wire you said you seen hanging down. see if they work that way
DO NOT do that. The that wire from the lights is green with a yellow strip, not a green wire. It is not a ground which is not a ground. Besides
Posted: Wed Jul 07, 2010 9:48 pm
by caito
it's dark tonight so i can't do anything more. if at all possible i'm going to get out there tomorrow and mess around with it some, but if i can't expect to hear back no later than the day after! i'm going to try and re-bolt everything etc. put everything back in its home, if you will.
if that doesn't work, i'll do the test-light route and let you guys know what i see from there.
you are all so incredibly helpful, and your responses are so prompt!
Posted: Wed Jul 07, 2010 9:49 pm
by fightingplankton
apologies for not seeing this sooner.
your problem is actually simple.
you're missing a wire that attaches to the tail light.
it goes down on that little tab that is part of the brass coloured ring at the base of your fixture. you can see the tab peeking out from behind the wires in the second photo.
all you need to do is get a bit of wire and run it from that point (solder if you have to) and attach it to the green wire in the first photo
ps. unlike the spree, the aero50 does not use the rack as ground. it has plastic around the whole light. there is a metal bracket that keeps it in place which attaches to the frame, but that's it.
Posted: Wed Jul 07, 2010 10:11 pm
fightingplankton wrote:apologies for not seeing this sooner.
That would do it. No ground = no lights.
I just looked at my spare Aero 80 tail light assembly and sure enough the tab needs a green wire on it that connects to the Green wire in the harness.
Posted: Wed Jul 07, 2010 10:18 pm
by fightingplankton
here it is attached to the light
here is where you attach it to the wiring harness
Posted: Wed Jul 07, 2010 10:24 pm
by caito
youre all GREAT!!!!!
i'm sorry if this is a stupid question, but since i'm trying to actually get my head around how these things WORK (one day i want to be answering questions instead of asking them)... i might as well go ahead and ask it anyway!
will just that one missing green wire cause none of the tail-lights to work because it is the ground?
Posted: Wed Jul 07, 2010 10:30 pm
by fightingplankton
should just keep the taillight from working.
you can see the wiring schematic in the manual towards the very last page
http://www.hondaspree.net/other/Aero50_SM_85.pdf
if your turn signals arent working, check your signal relay...browse through the whole electrical section of the manual, it should give you a quick understanding of how everything works.
Posted: Fri Jul 16, 2010 10:17 am
by caito
all bulbs have been replaced and ground wire successfully connected. upon closer inspection of the red wires leading to the fuse... theyre burnt. so is the fuse casing. this said, does the entire casing need replacing, or just the wires? also, there's a black... i don't know, maybe a fuse-box, that hangs out beside the battery casing, and is routed directly with the fuse. does it probably need replaced also?
we're pretty sure it's not the wiring harness anymore, and that we have targeted the problem specifically to this area (fingers crossed!)
are these two parts easily obtainable at an auto-parts store? if not, it's internet (or you guys
one more question -- how far back am i likely going to have to replace wiring?
EDIT: let me also note that i did check out the manual, but the poor photograph quality and explanation has me unsure whether it's the CDI unit, starter relay, or something else entirely. it has like... almost a loop on the side of the battery's casing where it hangs out at.
