Custom Wheels
jannick
Re: Custom Wheels
Post by jannick »
knucks wrote: Mon Jan 07, 2013 9:41 am Bumping this - Not sure you are right, Trafficjamz -
the bearings used, according to PowerSportsPlus, are 6200U - they have a 10mm inner diameter.
I purchased the 6200-2RS bearings for my new front wheel, they are 10mm and are sealed unlike the stock bearings.
Here is a good reference:
http://www.pibsales.com/pdf/6200.pdf
I stand corrected. You are right, the SR Elite 50cc uses 6200U bearings with a 10mm inner diameter. The 6200-2RS bearings that you purchased are the correct size and type for your scooter.
I appreciate you providing the link to the 6200 bearing specifications. You can also find it here at https://en.tradebearings.com/6200U-819982.html. This will be helpful for other users who are looking for the correct bearings for their SR Elite 50cc.
Re: Custom Wheels
Keep an eye on the dates of the posting. You just replied to a thread over 10 years old written by Abe Lincoln’s grandfather.
Re: Custom Wheels
Should I set autolocking on this board?
I've never bothered, but necroposting at this point in the board's life is probably pointless.
LMK thoughts.
MINICooperS
Re: Custom Wheels
Post by MINICooperS »
. . . and?
bonesv
Re: Custom Wheels
Post by bonesv »
MINICooperS wrote: Thu Mar 07, 2024 1:14 am
C3Killer wrote: Fri Jul 09, 2010 11:13 pm Where do you all get your alloy or custom wheels?
Have you considered chrome plating your stock wheels . . . or maybe the whole scoot?
The stock honda elite wheels are not worth it. I use chf50 wheels from a metropolitan and they are so much more sturdy and tubeless! Chrome those!
MINICooperS
Re: Custom Wheels
. . . and?
harleyracer59
Re: Custom Wheels
Post by harleyracer59 »
You could always buy some Japan alloy wheels. They’re 4x110? Bolt pattern and a ruckus/zoomer rear hub bolts to them and for front i use the elite 150 front hub. Same bolt pattern. But it has 105mm diameter drum brake. For upgraded stopping power.
bonesv
Re: Custom Wheels
Post by bonesv »
harleyracer59 wrote: Sat Mar 09, 2024 6:21 am You could always buy some Japan alloy wheels. They’re 4x110? Bolt pattern and a ruckus/zoomer rear hub bolts to them and for front i use the elite 150 front hub. Same bolt pattern. But it has 105mm diameter drum brake. For upgraded stopping power.
:thumbsup: Ya'll are serious! :bowrofl:
