80cc 4 stroke spree
az_slynch
Re: 80cc 4 stroke spree
Post by az_slynch »
mopar4u wrote:Will running straight pipe cause harm or decrease in performance? I would like to fabricate dual exhaust.
Four-stroke engines do not depend on exhaust backpressure as heavily as two-stroke engines. However, they do require some backpressure. If you do brew your own pipe, I'd recommend that you make it long enough to keep from burning the exhaust valve and if you go twin-pipe, make sure that the combined exit area of the two pipes is close to the inlet area of the pipe. if the outlet is too big, you'll sacrifice torque, which would hurt an engine as low-powered as the AF08E.
'64 Vespa 90 (V9A1)
'65 Allstate Compact (DS60)
'74 Vespa 125 Primavera (VMA2)
'81 Vespa P200E (VSX1) (2)
'83 Yamaha Riva (XC180K) (2)
'84 Yamaha Riva (CV80L)
'85 Honda Spree (NQ50)
'86 Honda Gyro S (TG50)
'87 Honda Elite (CH80)
'89 Honda Elite E (SB50P)
mopar4u
Post by mopar4u »
finished all wiring. Everything crosses over from the 80 to the spree. Some wiring is plug and play and some requires splicing along with help from the wiring diagrams. I think I'm ready to start working on making the body panels fit.....
vette66_00
Post by vette66_00 »
Cant wait to see what it looks like when your done.
On the exhaust if you run a dual make sure you run some kind of muffler, also this will give it a bit of back pressure. You want to make sure on 150cc the exhaust is at least 10" long to avoid cold air going back into the exhaust and burning a valve. If you are really set on changing the exhaust look for a 4 stroke Pitbike type or even a Go kart type (long tube with a RLV type screw on exhaust).
Here is a place that sell the kart Exhaust.. http://www.nr-racing.com/exhaust.htm
89 Honda Elite E 48cc bbk and gears all broken in... I get to 35 mph (gps) full out and Im 240 lbs. Need more speed
My toy.. http://www.youtube.com/watch?v=LWgZXLUy25U
A straight pipe will degrade performance but will hurt nothing. No pipe will cause issues. Duals would be interesting, but why?
elitedio
Post by elitedio »
Yeah make a pipe that is either scrambler style, wrapped around the cylinder or motoGP style and come out above the tire. I'd put some kind of muffler on it to prevent a headache. I made two mufflers from an ebay 125 Yamaha silencer. Cost was maybe 15 dollars.
1989 Elite E with 86cc Dio
mopar4u
Post by mopar4u »
ahh crap, run into a small snag. Now that I'm using the elite 80 hand controls I lost the threaded holes that hold the mirrors. I'm guessing law requires me to have mirrors in wisconsin. Any ideas how to mount my original mirrors?
The only thing I can think of is to drill a hole in the speedo cover plastic and try to bolt them to the plastic (see black circles in the picture). I think they will vibrate pretty bad though.
headlight cover.jpg (19.61 KiB) Viewed 5973 times
vette66_00
You could weld 6mm nuts to the bars.... Or do what I did and bought these on ebay, they work pretty good to. Bar End mirrors 3" and only took 6 days from auctions end to get. Order tonight get by Friday. LOL
mopar4u wrote:ahh crap, run into a small snag. Now that I'm using the elite 80 hand controls I lost the threaded holes that hold the mirrors. I'm guessing law requires me to have mirrors in wisconsin. Any ideas how to mount my original mirrors?
Switch back to spree controls.
Why did you swicth controls in the first place?
mopar4u
Post by mopar4u »
I switched so that things would work easier with the elite 80 wire harness, throttle cable and rear brake cable. I may have to switch back if the throttle and brake cable from the 80 work with the spree controls.
mopar4u
Post by mopar4u »
vette66_00 wrote:You could weld 6mm nuts to the bars.... Or do what I did and bought these on ebay, they work pretty good to. Bar End mirrors 3" and only took 6 days from auctions end to get. Order tonight get by Friday. LOL
will a bar end mirror work on the twist throttle side? do you have pictures what it looks like?
vette66_00
Yes they will work with twist throttle, they attach on the inside of the bar and it does not interfere with the twisting. Here's a pic.
mopar4u
Post by mopar4u »
:2thumbs: thanks, think I am going with the same thing. Why not, not much else is stock on my spree 80 anymore :thumbwink:
vette66_00 wrote:Yes they will work with twist throttle, they attach on the inside of the bar and it does not interfere with the twisting. Here's a pic.
wikked_spree57
Post by wikked_spree57 »
I thought about doing this with a Spree frame I got laying around. I got a CH80 motor and wiring that I've got no clue as to what to do with since nobody wants it, lol.
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
I would still just use the spree controls. I dont understand why you changed the whole harness just to do an engine swap.
How many wires even go to the engine anyway? Maybe 4 at most.
Honda keeps most of the wire colors the same between diferent models switching the hand controls over should not be that hard.
vette66_00
Any updates?
