Just got a Spree for 5$, need help
toad772
Re: Just got a Spree for 5$, need help
Post by toad772 »
tommy9345 wrote:Ok, So I found this. http://cgi.ebay.com/ebaymotors/Honda-NQ ... 0222250512
Says it fits multiple years blah blah.
Where the kickstarts supposed to be on my spree, theres a little gear that is connected to the big gear that the belts hooked onto, so I just buy that lever and screw it on or whatever? anyone got a guide? And Ill be jumping it tomorow first thing with my moms car battery.
The kick start goes on a little rod that sticks out from the trans cover.
PS3 it only does everything.
toboggan
Post by toboggan »
yes,that kick start lever will work.
and don't hot wire it, you can order keys from i believe tazland001 for 10 bucks i think. all you need is the serial code thing from the ignition body
tommy9345
Post by tommy9345 »
Ok, so Ill order that lever. But I need a key too, so Ill pm that guy and get the serial number and * make a key?
toboggan
Post by toboggan »
yes, i believe it's tazland001, and i think all he needs is that serial number. PM him for details.
toad772
Post by toad772 »
toboggan wrote:yes,that kick start lever will work.
You can get a new key from a Honda dealer too. He could just solder the wires back on the ignition when he got a new key and hot wire it till then.
toad772 wrote:
tommy9345 wrote:
toad772 wrote: Yes you can jump it off a car battery if you do not start the car(although it still probably wouldn't do any harm maybe blow the fuse) and yes you need a key to start it.
God d***, I need a key? What am I supposed to do if I don't have one?
Hot wire it.
Or just unplug the ignition switch all together and jumper the starter solenoid's 2 small wires, on to ground and one to 12 volts. The "Stop/Run" switch will stop it for you.
tommy9345
Post by tommy9345 »
I actually live less than a mile from a honda dealer. I could bring it down tomorrow actually. Would they help me get it going or just give me a key?
toad772
Post by toad772 »
All you need is the serial number and they can make a key for you.
toad772
Post by toad772 »
This is how the kick start goes on.
tommy9345
Post by tommy9345 »
Thanks for that, DOes it just screw on to the tran cover?
And also, what are the chances that this bike is a lost cause since its been sitting outside for like 6 months? I mean its a honda but what could be broken from being outside for so long?
toad772
Post by toad772 »
tommy9345 wrote:Thanks for that, DOes it just screw on to the tran cover?
The lever goes on that little rod and then you tighten up the bolt on the side.(you can see the bolt in the picture)
tommy9345
Post by tommy9345 »
Ok, thanks. Ordering it after I jump it tomorrow to see if it even starts, dont wanna buy the lever if it doesnt even start
toad772
Post by toad772 »
6 months isn't really that long the trans cover in that pic is off a aero 50 I am working on getting running that has been sitting outside for about 2 years.
toad772
Post by toad772 »
You will probably need to clean the carb before it will start.
tommy9345
Post by tommy9345 »
Ok, thanks. Ordering it after I jump it tomorrow to see if it even starts, dont wanna buy the lever if it doesnt even start[/quote]You will probably need to clean the carb before it will start.[/quote]
Ill do that if it doesn't start.
