Taz's Honda Pal Rebuild
tazland001
Re: Taz's Honda Pal Rebuild
Post by tazland001 »
More pics of the re-build. Ran into a problem with the gears but Tobaggan lathed it for me and it works perfectly.
tazland001
Here is a pic of the engine cleaned up a bit before I put in.
tazland001
If you notice the * end gasket(gear box gasket) sticks right to one side if you are careful. In my experience 9 out of 10 times the gasket will stick to one side. I have 48mm and the 15*82 gear ratio in this engine. That engine was filthy and I cleaned it with my drill and a wire attachment and of couse a little carb cleaner. lol
Taz
