Delete
Re: How to reach a true 65-70MPH?
mostly all guys here in oahu can hit 60 easy
i would go with a corsa with 7.5to1 gearings pg long with kelly pully 7 g weights pg long 28 oko etc no need port garantee can wack 65+
Delete
if you can get one for cheap,that is a very good pipe. works perfect with the mhr cylinder.
DorkoElite303
Top speed 68mph gps verified on a straight level road. Taiwan 85cc polish kit, 7:1 gears; 28mm oko carb, yosh pipe, aluminum flywheel, with after market variator and 9g rollers all the way round. 1.5k center spring and 1k clutch springs.
'07 Honda Goldwing 1800.
07' Honda CBR 600rr
'97 Honda Elite- parts bike
98' Honda Elite SA50 SR(85cc plus all bells and whistles)
00' Honda Elite SA50p S
83' Honda PAII (not running)
07' Honda CBR 600rr
7:1:1 gears and you touch 70mph but don't hold it there.....
- fastplastic
Re: How to reach a true 65-70MPH? ***Big update on page 2******
hey pm me with ur price on that cyc. if you wanna sell
- Trafficjamz
CAPT wrote:Ok, so here is my update...
I started wondering what else could be holding it back. So, I bought a ruima Variator from Limp and a brand new belt from Honda..
I immediately went for a ride... Its windy today, so there was a nice tail wind.. Anyway, the difference was immediate! It pulled good all the way to 68.5 (GPS) MPH!!!I gained 12.5mph with just those changes...
I can't believe I have been wasting all this time on cylinders and pipes when it was the stock variator and belt all along..
Now, I am wondering about 8.2 or 8.0 gears...
- Trafficjamz
Is yours a 72cc setup?CAPT wrote:I think that the belt was toast and the variator too.. The variator had big ridges in it...It was the only thing I hadn't ever thought about changing...
- z50r-ghost
CAPT,
***Congrats, dude - that's some great news!***
I work at a scooter shop and do chinese gy6 repairs all day long, with the occasional Honda / Yamaha now and then, and the one thing that's cheaper quality than a chinese scooter, is a chinese belt. Its amazing the difference in speed by adding a new belt. -The chinese belt's price may be tempting, but believe me, they are junk.
Yep dude, it's always the last thing that you would think that can be the biggest factor.
Glad to hear you now can put the power to the ground-
later, jon
later, jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
...my life story
1990HONDANS50F
- Munstah666
- Goped
No Man, you were'nt wasting your money in your cylinders, actually that's where you start first. Then you need to match your components like getting the right carb, the jettings, elevated ramp/plates & roller weights, clutch springs, pipe etc. It's all about playing and learning. As far as lowering your gears, you'll like it when you're cruising @ past 70 ... Ride Safe!CAPT wrote:Ok, so here is my update...
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
1StarGeneral
heres my setup. taiwan 72 , v8 pipe , 24 oko. 2k center and side springs. i forget what weights i get. 9:1 gears. 62 mph street bike verified. every one talking about no long full throttle runs ive run this thing so hard trying to blow it up , seems bullet proof. went from kahului to kihei approx 5 miles full throttle no heat seize and no temp gauge. runs like a champ every day with 3K + miles on the build
You guys ever notice the difference in the quality of materials used in a ruima taiwan bore and a italian mallosi or polini? What about the difference in timing between the 72cc italians and the bigger displacement taiwan bores? I asked the owner of vt what his professional opinion was on the power differences between the italian bores and the taiwan bores and he said "even though the taiwan bores have more displacement and meat to port, they still put out less power than a malossi or polini". I think 70 mph is a realistic goal when your using a malossi or polini unported. I think weight has a lot to do with it as well. I hit 74 radar clocked with no problem, but I only weight 155. My bike didn't bang all the way up to 75 of course but it did 60 easy.
