Page 2 of 4
Re: 86 Spree swap from an 87 Elite! Need some input
Posted: Mon Sep 13, 2010 8:34 pm
by Trafficjamz
nickisaninja wrote:I ordered an SE50 carb off ebay.
That should be here in a couple days! So! What do I do about filtering the air into the motor now? Should I trouble myself finding an se50 air box or should I throw on a universal air filter?
Would I have to change jets with a different filter?
Total 2cycle and carb newb here.
You will not be able to get much speed without the airbox.
Posted: Mon Sep 13, 2010 8:52 pm
by nickisaninja
ah ill check out the variator grease. My main concern is at 25 its blowing a lot of blue smoke and struggling.
Posted: Mon Sep 13, 2010 8:58 pm
by Trafficjamz
what do you have for an air box now?
Posted: Tue Sep 14, 2010 12:01 am
by nickisaninja
Running on the spree airbox right now
Smoking at idle and smoking a lot at wot
Posted: Tue Sep 14, 2010 1:47 am
by Trafficjamz
nickisaninja wrote:Running on the spree airbox right now
The spree air box might be too restrictive and causing a over rich condition.
Have you changed the jets?
Are you premixing gas?
What type of oil are you using?
Posted: Tue Sep 14, 2010 2:32 am
by nickisaninja
jets are factory, it smoked this hard with either both spree carb and se50 carb
no premix
valvoline 2 cycle, barely smoked anything out of the spree motor
smokes with or without intake box on
Posted: Tue Sep 14, 2010 5:44 pm
by nickisaninja
Could the oil pump be bad?
Posted: Wed Sep 15, 2010 2:19 am
by nickisaninja
You guys are right, the variator gives a good oomph off the line and a lot more accel.
I think the check valve at the end of the oil pump may be gummed open and gravity feeding oil slowly =[!
I'll try and remove it or just clean it out with carb cleaner.
http://cgi.ebay.com/ebaymotors/HONDA-AE ... 500wt_1182
would that muff work to de-restrict me?
Posted: Wed Sep 15, 2010 9:12 am
The stock-looking muffler definitely doesn't look much like an Aero or SE50 exhaust. See that constant-diameter header pipe leading to the muffler? The unrestricted scooters had at least a couple of diameter increases on the way to the can. There are probably better options out there ot de-restrict, if you're patient. Probably none cheaper, however. Perhaps as raw materials to cut-and-fab a chamber, this item's worth getting?
Posted: Wed Sep 15, 2010 11:39 am
by tw39515
Need one like this.
Posted: Wed Sep 15, 2010 1:07 pm
by nickisaninja
Gotcha. I might get it because the muffler from donor scoot had a battery leave itself all over and then sat for a while. It's in pretty bad shape and not worth repairing.
Are there any aftermarket options that will fit an se50 for under $100?
Posted: Wed Sep 15, 2010 1:57 pm
by PimpinSpree
lets see some pics of what the scooter looks like now
Posted: Thu Sep 16, 2010 5:16 am
by nickisaninja
Here's where I mounted the shock. Right behind the voltage regulator! I don't listen very well. Anyway I felt the frame at this point was strong enough to sustain a big 'ol hole drilled in it. I think I used the motor mount bolt and nut from the se50 for the shock mounting. I didn't weld anything either and not going to. Welding isn't necessary and WHAMMY everything is made just that much easier for this swap. Just drill a hole! Who knew.
There's the sad looking motor mounted in. I can't wait to finish this so I can button her up and hide all the ugly!
Posted: Thu Sep 16, 2010 6:11 pm
by Trafficjamz
nickisaninja wrote:Could the oil pump be bad?
Yes that is very possible.
Not the pump itself, but the rubber seals might be letting oil into the crank case.
Could explain all the smoke.
Posted: Thu Sep 16, 2010 6:18 pm
by nickisaninja
The elite was sitting for 10 years or more that would accumulate some oil in the case. I cleared it out and stopped smoking so much now it just has no power because of the lack of se50 airbox. Did you ship that box yet?
