"Officially I'm Broke"
veedubh20
Re: Ruckus Horizontal Minarelli Build
Post by veedubh20 »
that is taiwan yamaha zuma motor ( long block tranny)
bradthreee
Post by bradthreee »
Hey Taz,
Just as V-dub stated, its a 2004 Zuma motor. This is the long case Minarelli style engine that comes on the Zuma's 2002 and up.
As for the mounting of the motor to the Ruckus frame, there are a few options. I went with a frame that already had mounts welded on. The other option, which is a bit more expensive, are the bolt on engine mounts. Those are around the $500 range. If you were to DIY weld-on mounts, that would cut the cost dramatically
The other portion of the install would be the wiring. Originally the Zuma had a vacuum operated fuel pump, but I have read that with Zumakus(Zuma+Ruckus) swaps there is sometimes fuel cutting out at high RPM's. I'm running a Stage6 HPC crank that ups the RPM to 16,000 max, so I opted to run the stock Ruckus electric fuel pump to ensure constant fuel delivery througout the full RPM range.
bradthreee
Stopped by the shop last night and was pleasantly surprised to see the Ruckus coming together nicely!
The exhaust needed to be reheated and bent to fit onto the motor. It was originally for the European AeroX. EGT gauge sensor was installed as well and the wiring was good enough to start her up. All I have to say is DAYM this motor sounds like a beast!
Looks like it'll be ready within the next week or so.
bradthreee
This Express was also being worked on at the same shop. I thought it was pretty kewl :geekdance:
bradthreee
Picked up some new shoes today :rock:
They need a little TLC but they'll turn out just fine :D
bakaracer
Post by bakaracer »
Those stars are sick rims!! looks like your bike is coming along good.with that engine setup you got going on there,your going to like it.lots of power for a 70cc setup and your bike is going to look good too.
bradthreee
Thanks Baka I was soo excited when I picked up these Daytona rims! I had already started cleaning them up a bit when I took the pic, but man these things were dirty! They even had dog * all over them :sad:
I hope to have the bike back sometime this week so I can get these wheels put on :rock:
spree-rider
Post by spree-rider »
:2thumbs:
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
bradthreee
Stopped by the shop today,
and she's starting to take form. Almost there :geekdance:
Sorry about the plastic and tape, but you get the idea...
bradthreee
Here is sitting idle:
Here is in motion:
Spent all day cleaning up the wiring:
Still more work to do:
sanjuro
Post by sanjuro »
Looks and sounds mean. Video was too short though.
bradthreee
Im pretty new to the video thing :oops:
Ill take another one at idle for ya Vic :thumbsup:
bradthreee
bradthreee
Here is a couple with me on it :wasted:
Some others:
Still need to wire up the turn signals and tail light. Test fitting everything before I put on the Orange battery box, dont want to scratch that :cry:
bradthreee
Tuning now thanks to all those that are helping me along the way :thumbsup:
