Honda parts mash up. Bobber/Chopper Moped
bradthreee
Re: Honda parts mash up .
Post by bradthreee »
Mini Fatty in the back would look killer :imo:
bradthreee wrote:Mini Fatty in the back would look killer :imo:
I agree :2thumbs:
I tried to find a kymco zx50 enginge for this mash up.
the 12" tire would have looked better than the 10" on it now. :imo:
bradthreee
The zx engine is a longcase? Thats the only way to run a 12" in the back. Sym and Daytona makes a hub that fits the 95mm rear on the SA50 engine. Ive seen a couple of guys run a 10x5 mini fatty on their Dio engines, but it takes the proper stretched tire to make it work, as well as spacing the exhaust out wider.
If you're interested, I can find links to what I posted above :naughty:
Post by eliteguy50 »
bradthreee wrote:The zx engine is a longcase? Thats the only way to run a 12" in the back. Sym and Daytona makes a hub that fits the 95mm rear on the SA50 engine. Ive seen a couple of guys run a 10x5 mini fatty on their Dio engines, but it takes the proper stretched tire to make it work, as well as spacing the exhaust out wider.
When you space the exhaust, you could even cut it to take out some of the rise and rotate the nozzle. That would really set it off. :imo:
Raised the front bars up 3more inches, added the front headlight/speedo housing, and welded footpegs on the frame.
More of the light/ speedo
...and foot pegs
Spreetard
Re: Honda parts mash up. Bobber/Chopper Moped
Post by Spreetard »
You need to mount the tank so I don't knock it off. Again. :oops:
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Spreetard wrote:You need to mount the tank so I don't knock it off. Again. :oops:
I will try to get it mounted today........* :wink:
What kind of tank is that? Looks Sportsteresque...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _500wt_956
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _603wt_939
Harley :smile:
The tank and the headlight are not honda parts. :oops:
All the rest is honda.
I couldn't get your ebay link to load on my BB, Jamz. It appears to be an aftermarket replica of the 1959 "Peanut" 2.2-gallon tank.
Harley went to a 3.3 gallon capacity in the 1990s sometime. Same mounting points, in case you want to head cross-country.
Any chance you have a "late" '98-'01 single-bearing trans cover lying around?
Wheelman-111 wrote:Greetings:
Links fixed. :thumbwink: :thumbwink:
I will check to see about the trans cover.....but not very likely that I have one of those.
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
Hey Wheelman, i think i might have found one of those late covers for ya :thumbsup:
http://cgi.ebay.com/ebaymotors/1998-HON ... leQ5fParts
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
Petrock's 1984 Spree wrote:Hey Wheelman, i think i might have found one of those late covers for ya :thumbsup:
Dig one level deeper into the transmission: http://cgi.ebay.com/ebaymotors/ELITE-SA ... 4396898388
This is the cover he is looking for only with the single ball bearing.
:b2t:
Why are the forks pulled apart?
