I'll add check your own compression to Baka-san's advice. Easy and Cheap, with the $9.00 tester I posted up earlier. The compression test will give an indirect assessment of the integrity of the valves' seal to their seats. At 2800 miles, I'd be surprised if they were bad enough to matter. I agree the problem is more likely in the CVT system's belt and/or rollers.
1990 honda elite ch80 not going as fast as it should?
Re: 1990 honda elite ch80 not going as fast as it should?
also for one thing i've noticed when riding it on full throttle. the bike tends to be * (topping out at 35mph). anyone might know a clue to that problem? perhaps fixing that is the only matter really.
Change the spark plug. This is the most neglected maintenance item on a scooter. While changing the spark plug, do a compression test. Next check the air filter.
okie awesome. i'll check the manual for that. also one more thing. i believe something is wrong with my fuel tank or fuel injector? today i rode with a full tank of gas and only probably put on about 20 miles but the tank dropped to half now. experience with this matter folks?
Can someone give me a website where I can buy these parts?
Link to a parts source threadCan someone give me a website where I can buy these parts?
Could be a problem with the float valve, letting fuel pour out the overflow line while riding. Once stopped, a working vacuum petcock would shut off flow, and you might not see any fuel once stopped.today i rode with a full tank of gas and only probably put on about 20 miles but the tank dropped to half now. experience with this matter folks?
Thank you kindly mod c:
my speedometer and odometer is broken. can somebody give me a full detail explanation on how to connect the cable back? thanks!
If you have downloaded the Service manual like you should have, you would not need to ask this question. Look in the "Honda Service and Owners Manuals" section.kekkiumai wrote:my speedometer and odometer is broken. can somebody give me a full detail explanation on how to connect the cable back? thanks!
http://www.hondaspree.net/phpBB3/viewforum.php?f=11
