Ch-ch-ch-- no engine movement when trying to start
- Petrock's 1984 Spree
Re: Ch-ch-ch-- no engine movement when trying to start
I have no clue what you have done to this thing to try to make it start up so a few of the basic things would definately be...
1) Have you thrown that new plug in yet?
2) The air filter should be springy, not spongy. It should almost rebound after you let go of it
3) Clean, or replace, fluid lines
With that many miles on it, I would pull the cylinder head off of the motor and check the piston for excessive carbon build up
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Have you plugged the air intake to the airbox and tried to start it?
- killerpancake
so uhh, we're sure it has gas right?
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
Haha, of course.killerpancake wrote:so uhh, we're sure it has gas right?
I'll try checking out the stuff everyone suggested tonight, I'll let y'all know what happens.
Oh, and on the carb, what does the vac line connect to? I just found Dac's line explanation, and I'm trying to make sure I have everything in the right place.
Okay, I've a question about how the carb lines are put together. I've circled the...er... tubes that either have nothing on them or I'm not sure of.
http://i243.photobucket.com/albums/ff28 ... C11443.jpg
The top one sticks out facing the shock, and has nothing on it. It's perpendicular to the gas line.
The next one sticks out downward and is almost right below the top one I circled. Nothing connected there either.
The bottommost one (with the hose) is almost perpendicular to the drain screw, and right now it's connected to the crank case on the opposite side of where it has HONDA written on it.
Could y'all tell me where those go/what they are? Sorry I can't take a better photo, close quarters and all.
Here's your photojrmints wrote:Okay, I've a question about how the carb lines are put together. I've circled the...er... tubes that either have nothing on them or I'm not sure of.
and like many before me I would suggest downloading the manual for your model, you'll be amazed at what you can learn.
http://www.hondaspree.net/phpBB3/viewforum.php?f=11
1984 Honda NN50 Gyro
1986? Honda Aero 50
Served Onboard 94-97
1986? Honda Aero 50
I do have the manual, I just can't seem to make heads or tails of the carb.PolarIce wrote:Here's your photojrmints wrote:Okay, I've a question about how the carb lines are put together. I've circled the...er... tubes that either have nothing on them or I'm not sure of.
Unbarbed, cast aluminum standpipes are just vents. Air has to be able to exit the carb so that fuel can fill the bowl. Good practice to attach short lines to keep rain out and to reduce the evaporation rate from the carb, or you can leave them alone. There's a larger barbed brass fitting where the fuel line goes. Some carbs also have a 1/8" barbed fitting for the petcock vacuum line.
Where is your bystarter?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Looks like he doesnt even have one .
No wonder it wont start
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Nah, took it off to get a clearer photo of the carb. It's very much there.Petrock's 1984 Spree wrote:Looks like he doesnt even have one .
well make sure you put the bystarter on right and then try shooting some starter fluid in the air box next time you try to start it
1985 aero 50
ported
custom exhaust
ruckus vario
1K polini clutch springs
hopefully nh80 powered soon!
ported
custom exhaust
ruckus vario
NEVER ever use starting fluid on a 2 stroke!bc117 wrote:well make sure you put the bystarter on right and then try shooting some starter fluid in the air box next time you try to start it
1)The stuff washes the oil off cylinder walls leading metal to metal contact.
2) It can explode in the crankcase blowing the reeds out of the motor.
Use a mix of gas and oil as primer at 32 to 1.
New development: I've noticed that when I try to spin the fan manually, or kickstart, there's a spot where it starts being hard to spin. Once you push past that spot, it'll spin fine until you hit it again.
That's called compression, a requirement for the engine to run.
