Can a Lean Condition Cause Loss of Power?
scottinscotty
Re: Can a Lean Condition Cause Loss of Power?
Post by scottinscotty »
so when i'm cruising i should ease off the throttle rather than just let off completely?
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
ZMUD
Post by ZMUD »
Dude ride the * out of that thing. It ain't going to blow up and you know I carry a tow rope. :bowrofl:
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
kylebo
Post by kylebo »
I am going to try my pilot mod within the next two weeks. I will try it on a 47mm Taiwan bore
look up kylebo mods the pilot
01 dio, polini 72cc, 8.4 gears, 28oko, ruima crank, PG short, ported intake, 42.3 rolls
2nd build
86 aero
10-1 secondary gears form a dio.
arisol 46mm
pg short
carb? not yet
