Page 2 of 2
Re: spree runs excellant on center stand but wont pull me
Posted: Tue Apr 19, 2011 9:52 pm
by ciccanti38
me either but 25 years old and never conditioned something gotta go and rubber is the worst thing for dry rot
Posted: Tue Apr 19, 2011 10:01 pm
ciccanti38 wrote:me either but 25 years old and never conditioned something gotta go and rubber is the worst thing for dry rot
Even 25 years ago O-rings weren't rubber and they only rot (if they were rubber) when exposed to the air, which when squashed between the carb, insulator and intake does not happen.
Posted: Tue Apr 19, 2011 11:08 pm
by ciccanti38
what you reccomend i do runs fine on stand but not under load
Posted: Tue Apr 19, 2011 11:11 pm
by Trafficjamz
ciccanti38 wrote:what you reccomend i do runs fine on stand but not under load
Stripped threads in the carb?
by Trafficjamz
Posted: Tue Apr 19, 2011 11:22 pm
Again, what it does on the center stand means
NOTHING!
Your main jet fuel circuit is screwed, probably the emulsion tube.
http://hondaspree.net/wiki/index.php5?t ... r_Cleaning
http://hondaspree.net/wiki/index.php5?t ... ture_Guide
Posted: Wed Apr 20, 2011 1:12 am
by Ricerider
Just replace the orings, they are 15 cents a piece at the hardware store, ace, true vale etc.
Built a spree for the lady last year, ran good for 200 miles and then started bogging at random, seemed to change depending on engine temp, replaced the orings and and that was it. Research the venturi effect and how carbs work and it will make sense
Posted: Wed Apr 20, 2011 6:19 am
by ciccanti38
i understand how the feul system works with vacuum and all that is what seems to be the problem gonna get new o rings today and try it out thanks for the help
Posted: Wed Apr 20, 2011 1:09 pm
by Trafficjamz
ciccanti38 wrote:got everything running perfect but wont even pull me on the level has been sitting since last august anyone have an idea whats wrong
Gummed up carb is probably your problem
Posted: Wed Apr 20, 2011 8:36 pm
by ciccanti38
changed o rings and vacuum line runs pretty good but bogs every now and then think it really needs run time
Posted: Thu Apr 21, 2011 10:30 am
by Ricerider
Did you go thru the carb yet? If its your first time it might take hour to do but it well worth it. Get yourself some chemtol at autozone (dont get in eyes
) wear glasses....
Pull out every screw you can find including the tube behind the main jet, you have to push it out the bottom of the carb from the top. It a brass tube about 1" long, there are holes in there that tube that have to be spick and span. Then use a guitar string or piece of wire and verify all channels are clean including the main jet (only flat head screw in there)
I like to spray chemtol in the carb and force it thru with the air compressor, it will mist out the other end and you will know it all clear.
Gummed up carb will lean the engine out, not a question of if it will burn up its when.....
Posted: Thu Apr 21, 2011 4:01 pm
by ciccanti38
carb was gone thru twice everythings clean all jet all vent holes the more i run it it gets better each time it has been sitting awhile so i think till the carb and the oil injection run itll b fine thanks to all for your help dont usually work on these mainly dirt bikes thought it would be an intriging exp. to take this on
Posted: Sun Apr 24, 2011 5:00 pm
by tru72
did you check the reed cage?
