Page 2 of 3
Re: 1987 SE50 naked scooter project
Posted: Thu Jun 23, 2011 12:45 pm
by TiffanySpree
I was wondering about that. It only came with the side piece around the fan. It does blow air over the cylinder and head pretty good. I thought that since I didn't have body panels, I may be safe. Any opinions or FHE on this?
I found the fan shroud on my local dealer site:
SHROUD
19620-GR1-020 (replaces 19620-GR1-010) 001 $22.37 $20.13
Posted: Thu Jun 23, 2011 2:23 pm
Over the past 3 years, I've followed a few threads where people got cute with going shroud-less. None of them ended well...
YMMV
Posted: Thu Jun 23, 2011 2:38 pm
by Trafficjamz
Posted: Thu Jun 23, 2011 5:09 pm
by TiffanySpree
Wheelman-111 wrote:Greetings:
YMMV
A couple posts back you digged it. Now you don't like it? Bad seat chop??
Posted: Thu Jun 23, 2011 5:39 pm
by MopedMark
TiffanySpree wrote:Wheelman-111 wrote:Greetings:
YMMV
I am pretty sure he was just backing me up on the top end shroud.
Posted: Thu Jun 23, 2011 5:45 pm
by TiffanySpree
Oops! I read shroud as body panels. I have to read more thoroughly and carefully. My bad. Carry on...
Posted: Fri Jul 08, 2011 2:29 am
by sum-azn-kid
I noticed in your flickr pics you had the metro brake on the exhaust side(looks alot cleeaner with brake line going back), did that mean your speedo gear spun backwards? basicly could you speedo still read?
Posted: Fri Jul 08, 2011 8:23 am
by TiffanySpree
Nice observation! I was hoping it was true. But no, the elite speedo was reading backwards. I flipped it back. It reads about 5mph slow. I'm not sure if that's from the metro front brake plate or just speedo error. But yeah I tried it in hopes of cleaning up the cable routing. Back to the drawing board!!
Posted: Fri Jul 08, 2011 11:46 am
by Trafficjamz
TiffanySpree wrote:Nice observation! I was hoping it was true. But no, the elite speedo was reading backwards. I flipped it back. It reads about 5mph slow. I'm not sure if that's from the metro front brake plate or just speedo error. But yeah I tried it in hopes of cleaning up the cable routing. Back to the drawing board!!
It probably reads slow because the met tire is
way bigger than the stock front tire of an 87 elite.
Posted: Fri Jul 08, 2011 1:25 pm
On both '87 Aero and 2001 Elite models, the Met 90/90 tire nearly perfectly corrected the optimistic Honda speedometer error. GPS was within 1-2 percent of speedo reading, personally observed. The 3.50 tire caused about a 3 percent pessimistic reading. (31 MPH on GPS = 30 on the Speedo, my current setup - also personally verified.)
BTW I do like the naked look without frame covers. I was indeed referring to running the engine without the cooling shrouds. I still believe that to be a Very Bad Idea. YMMV...
Posted: Fri Jul 08, 2011 1:53 pm
by fightingplankton
i like this build, been following it and just figured out what i think it needs.
paint the oil tank black. of course, leave a vertical strip so you can see the oil level.
i think it'd make it look more complete.
Posted: Fri Jul 08, 2011 2:23 pm
by sum-azn-kid
Was you front end lifted when you put on the metro frontend or the same height as stock?
Posted: Sat Jul 09, 2011 9:02 am
by TiffanySpree
I measured it with my iPhone gps. Not sure of it's accurracy. Are all the brake plates the same gear ratio?
About the fan shroud, it's already bolted on and I feel much better about it. Thanks for the tip and the shroud!
Posted: Sat Jul 09, 2011 9:09 am
by TiffanySpree
fightingplankton wrote:i like this build, been following it and just figured out what i think it needs.
Yeah, good idea! I may just do that. I really like the exposed strip idea. Since I removed the wiring for the level, I'll need it. But right now, I'd rather go scoot around. The latest addition is a Canadian market Givi e230 23 liter hard case. I'll load pics later. Great accessory! I can lock my cable and helmet in it. It easily carries a few items for grocery run too. I can swap it between scooters or my Ducati Monster.
Posted: Sat Jul 09, 2011 9:12 am
by TiffanySpree
sum-azn-kid wrote:Was you front end lifted when you put on the metro frontend or the same height as stock?
No it seems level. I was debating over putting an extension block for the shorter rear Ruckus shock. If I did, the rear tire will touch the ground when it's on the centerstand.
