Re: How do I make my 85 spree do this:
Posted: Wed May 04, 2011 10:58 pm
What do you get for speed with Taz Gears?
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://hondaspree.net/hondaspree.net/phpBB3/
http://hondaspree.net/hondaspree.net/phpBB3/viewtopic.php?t=18810
44mm bbkadaily13 wrote:is the 38 mph with stock everything else
Can I add a kickstart to my 85 Spree w/o any kickstart on there now?chrisdors wrote:Even with the 44mm? Or just more of a concern with the 48mm?Trafficjamz wrote: I would try to locate a kickstarter ASAP. Big Bore + electric start = dead battery
Yes, you find a parted out 1986 or '87 and get the parts there.CNI Dawg wrote:Can I add a kickstart to my 85 Spree w/o any kickstart on there now?chrisdors wrote:Even with the 44mm? Or just more of a concern with the 48mm?Trafficjamz wrote: I would try to locate a kickstarter ASAP. Big Bore + electric start = dead battery
What do you recommend for a complete reliable performance setup or kit on the '85 spree ?
TIA
Bill
andythespreeowner wrote:get a DIO big boar kit. there only about $100 and easy to install. that should make your spree go atleast 35mph easy
do you know what a dio is?andythespreeowner wrote:get a DIO big boar kit. there only about $100 and easy to install. that should make your spree go atleast 35mph easy
