Spree Intake is Here 21mm carb
dyehardfan
Re: Spree Intake is Here 21mm carb
Post by dyehardfan »
This is a brand new Honda Spree 50 (NQ50) 21mm carb kit. This kit comes with a power intake kit including the upgraded 4 vavle reed cage and reeds, 21mm carb, and throttle cable. Just bolt on and go. What a great improvement for the air flow on the spree. No one else in the world provides this carb kit for the spree. I am the only one. Give your spree the acceleration it deserves.
Bear, no offense, but nowhere in the description does it say what type of carb it is, what type of reeds are used or if I can get the throttle cable in black instead of blue. I apologize for not knowing enough to just know off hand that this was the CT Manifold. I'm a complete fledgling to the world of scooters and 2-stroke motors. I'm not an idiot, i'm only uneducated. I assumed that this forum was for the discussion and education in the ways of the Honda Spree and/or Elite. I'll probably never know half of what you do on this subject, but I sure am trying to learn.
Bear45-70 wrote:If this doesn't tell you what you need to know, Nothing will.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... _500wt_956
1987 Honda Spree:
*Complete Engine Resto/Mod
*Engine Torn Down
*Replaced Crank/Rod/Bearings
*Taz 48mm BBK & Gear
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
*Paint - Hunter Green & Saddle Brown Seat
It is a 21 mm OKO flat slide, good God I can look at it and tell that. But I know this because at the start of this thread, that is what taz says it is.
tazland001 wrote:The spree intakes came in today. Wow. They really add some serious acceleration to my spree with the 48mm kit. Takes off very strong. It was raining and I have to dial it in a bit. Will post pics tomorow. I am running a 21mm carb. hehe. Wait til you see this. :naughty:
Taz
Also in the flea-bay title it says
"Honda Spree (NQ50) Performance 21mm Carburetor Kit"
dyehardfan
Bear45-70 wrote:It is a 21 mm OKO flat slide, good God I can look at it and tell that. But I know this because at the start of this thread, that is what taz says it is.
Taz
Exactly, you can look at it and tell because you have experience in the subject matter. I was literally given a broken down Spree 3-4 weeks ago and began tearing it apart 2 days later. I had no way of knowing that this was an OKO brand carb so therefore had no way of researching it to learn more about it. That's why I started asking questions. There's no reason to be an *, just ignore my questions if you like. :eyeroll:
You've been quite helpful to me since I started visiting this board and I appreciate the knowledge you have passed on. That being said, I would appreciate if you wouldn't be such a *.
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
Taz
You are a * head to stupid to see what is in front of you. All CT intakes have fiberglass or carbon fiber reeds. The carb sizes is 21 mm and the brand is OKO. So what else there to know about this setup? NOTHING! I have no patients for stupid.
dyehardfan
Patience? That's probably what you meant.
I now know that the brand is OKO, thanks to your graciousness. I now know that the reeds are fiberglass thanks to petrock...who didn't have to be a * to answer my question, for the record. I wasn't aware that no CT intake ever produced used metal reeds until your last post, so thank you for that. Oh, and I think you meant TOO stupid and not TO stupid. Again, like I said earlier, I'm not stupid, I can manage a computer network of 1400 nodes in 27 remote offices while perusing the hondaspree.net. I am simply uneducated on the subject matter and don't like board bullies.
I will find other sources of info from here on out, so feel free to not take the time out of your miserable life to respond to any further questions that I pose.
I am not really sure what your problem is, maybe you think I'm badgering Taz for info, but I'm curious by nature and am trying to learn as much as possible.
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
Patience?
And no patience leads to mistakes.
dave03wj
Post by dave03wj »
I don't know much about these 2 stroke carbs, but if it was an OKO it would probably say OKO on the side. However, I have done some homework, and it helps that I have this carb (Bought the kit from taz) and it says YSN on the side of the carb. It is a PWK style carb, and it takes Keihin hex style main jets, and 21 series pilot jets. It came with a 42 pilot and a 102 main. However, i think with the environment I'm in, the 102 was a little too rich. So I stuck a 95 in it, and it runs good. I'll keep you guys posted as I put more miles on it.
Like I said, I don't know alot about this stuff, but I am just telling you what I've discovered.
dyehardfan
dave03wj wrote:I don't know much about these 2 stroke carbs, but if it was an OKO it would probably say OKO on the side. However, I have done some homework, and it helps that I have this carb (Bought the kit from taz) and it says YSN on the side of the carb. It is a PWK style carb, and it takes Keihin hex style main jets, and 21 series pilot jets. It came with a 42 pilot and a 102 main. However, i think with the environment I'm in, the 102 was a little too rich. So I stuck a 95 in it, and it runs good. I'll keep you guys posted as I put more miles on it.
Much appreciated. This was the type of information I was looking for.
1987 Honda Spree:
*Engine Torn Down
*Taz Carb/Intake
*Custom Exhaust
*Porting and Tuning
*Upgrade Rear Shock
*Upgrade Brakes
z50r-ghost
Post by z50r-ghost »
...I just wanted to add I do not own a spree, but if I did Taz's kit would be as good as purchased! That kit looks great, Taz! (applause)
j
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
