1985 honda spree wont start! please help
KillinSpree
Re: 1985 honda spree wont start! please help
Post by KillinSpree »
I think everyone gets the point!
1984 Honda Spree White
1987 Honda Spree Blue
tazland001
Post by tazland001 »
Well on a spree the compression for a running engine is 90 min and around 120 max for a stock application. Test one for yourself and see. Trust me I am right on this one.
Taz
toad772 wrote:
KillinSpree wrote:Whats your compression reading? 120psi MINIMUM. I learned this the hard way an got an earfull from the one an only BEAR! Anything less and you need to pull off the cylinder to see whats causing the low compression issue.
Bear said 114 minimum.
Actually even at 90 PSI the engine will still run, just a little slower on the top end. It won't even start once you get below 70 PSI.
tazland001
yahh but they are to start and hard to idle at 85 to 90. I guess this kid prob wont even do a compression check anyways.
Taz
tazland001 wrote:yahh but they are to start and hard to idle at 85 to 90. I guess this kid prob wont even do a compression check anyways.
Taz
true, but you can start them and they will run.
andythespreeowner
Post by andythespreeowner »
ok i checked compression and it was at 120 which should make it so it starts up alteast!!!!! but still nothing!! :cry: :cry: :cry: :cry:
any ideas?
its getting spark!!!
might it have something to do with the auto-bi-starter???
Do you actually have gas in the carb? If you do is it getting thru the carb into the intake system? Spark? Does it just arc the plug gap or will it jump a 1/2" gap. Jumping a .030" plug gap is easy but will not run an engine.
andythespreeowner
yeah gas is getting into the carb and the carb is very clean so maybe its a reed?? and yes it is getting a good amount of spark
andythespreeowner wrote:yeah gas is getting into the carb and the carb is very clean so maybe its a reed?? and yes it is getting a good amount of spark
Just because you think the carb is clean means nothing (* pretty on the outside means nothing). If the idle circuit and the fuel feed to the bystarter are plugged (both extremely small passages that normal clean will never clear), you engine will never start. Have you tried manual choking or manually priming to start? If that works you have a plugged idle and probably a plugged bystarter circuit.
martynkim
Post by martynkim »
I agree with Bear not to mention Air filter what are you running? or are you?
wood10214
Post by wood10214 »
I did had problem to start mine also, first time was the carb (I thought it was clean, but was NOT), second time was the air filter box (the air box just doesn't close all the way), the Honda is very sensitive.
Clean the carb and check the air filter.
I don't mod my scooters to go Fast, just want to keep it running!
87 Elite SE50
86 Elite CH150
98 Yamaha Zuma 50cc
andythespreeowner
i dont have a air filter but i stuck a peice of foam were the air filter should be in the air filter box and i feel like that would be good enough to start... i also took the carb completely apart and the float, the bowl, and all the jets seemed pretty clean (i then put it together correctly again)
andythespreeowner
by the way thanks for helping me out!!!!
i dont know what i would do without this site
KillinSpree
Are you giving up now?
andythespreeowner
no at first i was going to but now that i think about it i could fix it even if it takes me a month
because i really like honda sprees and other honda scooters so its worth it and i think im gunna completely restore it and make it nice :geekdance:
