Rings ONLY ONE
maddog
Post by maddog »
The aero tank is smaler than the "S" You can cut & expand the aero fuel tank using the exising oil tank space & specs. My work will only be done on the mainland, cheaper & better quality!
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
all you goota do is T-tap the oil tank and fuel tank which is easily done. The tank difference between the S and the aero is not that much. but every little counts when you're modified.
hrnytrtlsgsxr
T-tap on an 87
