headlight not working!!
Mystic
Re: headlight not working!!
Post by Mystic »
See that? :naughty:
How did you remove the glass?
Mystic
Post by Mystic »
Witchcraft.....hahha nah it was already broken out a long time ago whoever scratched their initials in there
Mystic wrote:I decided to show you right now how it can be unsoldered :D newbie indeed
So your theory and thinking is to unsolder it regardless if it is bad or not. Also you do not have to unsolder anything to test it. Only a moron would screw up the head light to test it. You are assuming facts not in evidence. Image
Mystic
Post by Mystic »
No you are putting words in my mouth bear. He said he couldnt get the headlight apart for one and thats how you get it apart. I just sorta figured he already knew how to test to see if it was any good before he went through the trouble. I already know for certain mine is bad
Mystic
Post by Mystic »
If you dont know andy, you can test the bulb by touching a multitester to the ends of the wires where they hook into the bulb, if the hands move the bulb is good ground is green I believe and white and blue are hot
