44mm bbk timing
guen84
Re: 44mm bbk timing
Post by guen84 »
I hope so my engines only a single cylinder dumb *..
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
Re: 44mm bbk timing
guen84 wrote:I hope so my engines only a single cylinder dumb *..
That engine is 6 single cylinder engines all tied together by a single crank, but each cylinder is individually tuned. But each cylinder is bigger than your warm sticks. But of course you are the dumb *.
guen84
Re: 44mm bbk timing
Post by guen84 »
Wow now your like the guy with the R1 who wanted to race me at the stop light. No comparison im building a scooter not a time machine...
Re: 44mm bbk timing
guen84 wrote:Wow now your like the guy with the R1 who wanted to race me at the stop light. No comparison im building a scooter not a time machine...
You really are too stupid to get it. Image I was tuning 6 engines at once to get this monster to run. I also has a V-4 cylinder engine with 4X2 barrel diaphragm carbs on it. I have forgotten more about tuning than you are every likely to know. Never once said a thing about racing you or anyone.
guen84
Re: 44mm bbk timing
Post by guen84 »
No u dont get it stupid.. We r giving u a hard time just like u give everyone else. Why dont u help people instead of bash them.
Re: 44mm bbk timing
guen84 wrote:No u dont get it stupid.. We r giving u a hard time just like u give everyone else. Why dont u help people instead of bash them.
You don't know enough or have enough experience to give me an easy time much less a hard time. Image
ZMUD
Re: 44mm bbk timing
Post by ZMUD »
Dude! I forgot more than you know! :jack: ....And my R\C Boat is faster than yours! :bowrofl:
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
1"uni-filter,Keli 9g
1k center,8.44 gears,ZX Trans
V8 Pipe,IRC MB38 80/90 tires
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
1" Uni-Filter,8:44gears
Re: 44mm bbk timing
ZMUD wrote:Dude! I forgot more than you know! :jack: ....And my R\C Boat is faster than yours! :bowrofl:
Mine doesn't even start to go until your top speed. Unless you are actually doing well over 100+ mph, don't talk to me about fast. My play/ski boat ran over 70 mph. My race boats were FAST!
fastplastic
Re: 44mm bbk timing
Post by fastplastic »
good luck bear these morons don't get it :crazy:
ZMUD
Re: 44mm bbk timing
Post by ZMUD »
fastplastic wrote:good luck bear these morons don't get it :crazy:
apparently you don't get it!!!! We asked about boost port timing and it turned into a s*** show!!!!! :crazy: So go back to sucking bear off and onto the next thread!! :jack:
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
Re: 44mm bbk timing
You've got the cylinder, measure it you nitwit. To stupid to think for yourself. :crazy:
ZMUD
Re: 44mm bbk timing
Post by ZMUD »
No I was waiting for you to tell me everything you dont know about this and think you do!
94 elite 50s
66cc bbk
118jet/Pre-Mix32:1
H4 H.I.D
94 elite 50sr
50mm BBK,105jet
Re: 44mm bbk timing
ZMUD wrote:No I was waiting for you to tell me everything you dont know about this and think you do!
Still too stupid to figure it out for yourself. But then we expected no less. There is really not much point in telling you anything. You wouldn't understand even if we dumbed it down to the 1st grade level you normally operate at. Image
fastplastic
Re: 44mm bbk timing
you wanna know about port timing use the search button or make a thread about how two morons blew up a bore and wine about it... opps did i say that out loud :jack:
tazland001
Re: 44mm bbk timing
Post by tazland001 »
Bear is right. Next time look at the ports. Get a dremmel and knock the burs off if any. Then polish it. Not rocket science. I do this on all my kits. Takes like 5- 10 min.
Also I got the pics you sent me. The port looked a little rough but next time you get a kit you will know what to do. Remember dont WOT these things out of the box. The break in is the whole trick for longevity.
Taz
