Half throttle faster than WOT?
Re: Half throttle faster than WOT?
bakaracer wrote:what size inlet is on that pipe? have you tried changing the main jet by going smaller or larger? what temps are you seeing at wot?
the inlet size is 32mm
the jets are 145 and 60 right now
It uses to be @ 160 and 60 .....but that did not run as well.
In the 1/8th mile CHT read about 350-375
No plastic cooling shrouds are installed since I only race it for short distances. :smile:
bakaracer
Post by bakaracer »
so you worked your way down from a 160 to a 145? or just drop down straight to a 145?
bakaracer wrote:so you worked your way down from a 160 to a 145? or just drop down straight to a 145?
160 -155 -145
at 145 it felt "snappy" off the line and the small bog, when taking off, had gone away.
bakaracer
Post by bakaracer »
have you tried dropping the pilot down to a 58 ? then play with the main? the bigger pilot would be more for street riding where in drag racing you want all the circuits to be at almost perfect air to fuel ratio.
bakaracer wrote:have you tried dropping the pilot down to a 58 ? then play with the main? the bigger pilot would be more for street riding where in drag racing you want all the circuits to be at almost perfect air to fuel ratio.
What main jet to go with the 58 pilot?
bakaracer
Post by bakaracer »
try it with your 145 and see how it feels.
