WAY too much gas!!
No_Stopping_A_Spree
Post by No_Stopping_A_Spree »
If I suck on the bottom line, it will let some air through so then if i blow and then suck i usually don't get any air. so i would say sometimes(if it is dry in there it shuts every time, but if there is some gas in it it will not shut all of the way so i blow it out and its fine)
MySpree
Post by MySpree »
did u re assemble your carborator right?
No_Stopping_A_Spree
i'm sure i put the carb together correctly. I remember cleaning the petcock the one day and now it hasn't worked since. It's fine to use about 50psi to blow in it through out the whole petcock isn't it ?
No_Stopping_A_Spree wrote:i'm sure i put the carb together correctly. I remember cleaning the petcock the one day and now it hasn't worked since. It's fine to use about 50psi to blow in it through out the whole petcock isn't it ?
No, it's not OK. Did you blow 50 PSI through the vacuum pickup? If you did, that's likely your problem. If so, gas will be pouring out through the lower petcock connection (vacuum) when you pull the hose.
MySpree
Post by MySpree »
yea... thatll blow the petcock...
No_Stopping_A_Spree
ok.....so how much would a new petcock be from honda because thats what I did....or would a petcock off of another spree that isn't the same year as mine work
MySpree
Post by MySpree »
i got an petcok/
No_Stopping_A_Spree
as much as I want a used one, we don't buy over the i/n...thanks anyway myspree..and thanks for all the input with my problem :D
I'm just hoping a local guy has a petcock, I got lucky and got a muffler when I needed it. I remember it took him a few days to find it for when I needed it last year, since he has the parts and wrecked mopeds in a large barn. I should check out his mopeds. He said he had a few razzs and some hondas that were in crashes and fires, it would make a fun project. This was last year though so I probobly wouldn't get so lucky.
myhonda
Post by myhonda »
i got 2 petcocks but im usen them both on one ped. i felt the need for a second gas tank.
myhonda wrote:i got 2 petcocks but im usen them both on one ped. i felt the need for a second gas tank.
Pictures?
No_Stopping_A_Spree
that is a cool idea, could you take some pics?
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
the oem spree petcock is like $50 but there is the one for the 87 which i believe is cheaper.
myhonda
Post by myhonda »
yes i will but not today. i dont know where my cam is right now
MySpree
Post by MySpree »
diff years have diff sizes!
No_Stopping_A_Spree
well I really don't know what i'm going to do at this time. I can't get ahold of the guy and since I don't have $50 or don't buy off the i/n the spree is just going to sit for awhile :cry:. I'm kinda hoping if I get ahold of the guy he still has some old mopeds that look nice but don't run because for all I know they could just have really dirty carbs or something I'd even get a few junk ones to mix and match parts onto the better looking one. I can only hope.
