72cc Polini kit.. Suggestions on Carb and Intake?
Re: 72cc Polini kit.. Suggestions on Carb and Intake?
scottinscotty wrote:or are you saying to NOT over carb. it.. maybe stick with a 19mm or 21mm carb.. and all this mess i hear about oko issues makes me not wanna buy one.. :surprise:
Over-carberating creates tuning issues making getting the mixture right harder and in my opinion that is why so many have extreme tuning issues. Honda on their CR80 dirt bike used a 24 mm carb for years and that is a true Hi-performance engine with a many geared transmission to help keep the motor in the power band. But a scooter does not have that advantage so you need to back down on the carb size to improve the low and mid range for improved street performance. Besides that just how much time do you actually spend at at WOT and max speed? A full race engine sucks as a street engine. FYI, I have 3 OKO carbs waiting for their intended scooter to reach the front of the to be worked on list. I also have 2 over-sized Keihin carbs waiting also for their scooter turn.
scottinscotty
Post by scottinscotty »
I see.... i don't spend very much time at top speed... i ride my scoot to and from work almost every day... and i might hit 50mph, alot of stop and go.. so would you suggest that i get a good exhaust pipe, or intake and carb first?
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty wrote:I see.... i don't spend very much time at top speed... i ride my scoot to and from work almost every day... and i might hit 50mph, alot of stop and go.. so would you suggest that i get a good exhaust pipe, or intake and carb first?
Most good after market pipes are all about top speed. There are a couple but............................
scottinscotty
But............ ? ?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty wrote:But............ ? ?
I'm not up on the BBK pipes so I can't name one for you. Wheelman and bakaracer would be better choice to ask. I know what I'm looking for for my Aero 50 but can't' help you on you 72cc Polini setup.
scottinscotty
so.... Pipe Or intake & Carb. wich one should i do first?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
I have found that the stock exhaust is quite adequate for an increase on the intake side. Go with the intake and carb.
scottinscotty
well i have the techingas pipe on it.. so that's a def. improvement over the stock.. so i'm gonna do carb and intake then... and will go with the chrome ct... and a oko 21mm ... as long as you guy's think the quality is there...
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
evilone
Post by evilone »
scottinscotty wrote:and will go with the chrome ct... and a oko 21mm ... as long as you guy's think the quality is there...
Do it.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
scottinscotty
Do i need to buy an new throttle cable? or can i use my stock throttle cable? and i need to buy a new one... where do i get it?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
scottinscotty
and where should i start as far a idle and main jets?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
guen84
Post by guen84 »
21mm carb- 45 pilot 112 main
24mm carb- 50 pilot 120main
28mm carb- 55 pilot 132 main
and your not gonna beat joe with them 8.44's took me 11,000 rpms and a bbk kit to do it!!! :naughty:
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
scottinscotty
What about throttle cable? is it different? and what abou dellorto jets? where should i start if i go with those?
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
Get the 21mm OKO and CT Manifold.
Also get a roller kit of assorted weights for your variator.
And your also going to want to get an idle jet kit and the small main jet kit from treatland as well. :thumbsup:
The 21mm works great when you get it going. I've got one on my corsa, so if you do decide to uprgade to a corsa it'll work just as well as it will on your contessa
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
veedubh20
Post by veedubh20 »
Need 28mm pwk carb and center spring 1500. And clutch spring 3000 rpm hit over 70 mph
