Page 2 of 2
Re: 72cc Polini kit.. Suggestions on Carb and Intake?
Posted: Sat Jul 30, 2011 6:49 pm
scottinscotty wrote:or are you saying to NOT over carb. it.. maybe stick with a 19mm or 21mm carb.. and all this mess i hear about oko issues makes me not wanna buy one..
Over-carberating creates tuning issues making getting the mixture right harder and in my opinion that is why so many have extreme tuning issues. Honda on their CR80 dirt bike used a 24 mm carb for years and that is a true Hi-performance engine with a many geared transmission to help keep the motor in the power band. But a scooter does not have that advantage so you need to back down on the carb size to improve the low and mid range for improved street performance. Besides that just how much time do you actually spend at at WOT and max speed? A full race engine sucks as a street engine. FYI, I have 3 OKO carbs waiting for their intended scooter to reach the front of the to be worked on list. I also have 2 over-sized Keihin carbs waiting also for their scooter turn.
Posted: Sun Jul 31, 2011 12:30 am
by scottinscotty
I see.... i don't spend very much time at top speed... i ride my scoot to and from work almost every day... and i might hit 50mph, alot of stop and go.. so would you suggest that i get a good exhaust pipe, or intake and carb first?
Posted: Sun Jul 31, 2011 12:44 am
scottinscotty wrote:I see.... i don't spend very much time at top speed... i ride my scoot to and from work almost every day... and i might hit 50mph, alot of stop and go.. so would you suggest that i get a good exhaust pipe, or intake and carb first?
Most good after market pipes are all about top speed. There are a couple but............................
Posted: Sun Jul 31, 2011 1:14 am
by scottinscotty
But............ ? ?
Posted: Sun Jul 31, 2011 1:34 am
scottinscotty wrote:But............ ? ?
I'm not up on the BBK pipes so I can't name one for you. Wheelman and bakaracer would be better choice to ask. I know what I'm looking for for my Aero 50 but can't' help you on you 72cc Polini setup.
Posted: Sun Jul 31, 2011 11:27 pm
by scottinscotty
so.... Pipe Or intake & Carb. wich one should i do first?
Posted: Sun Jul 31, 2011 11:30 pm
I have found that the stock exhaust is quite adequate for an increase on the intake side. Go with the intake and carb.
Posted: Sun Jul 31, 2011 11:37 pm
by scottinscotty
well i have the techingas pipe on it.. so that's a def. improvement over the stock.. so i'm gonna do carb and intake then... and will go with the chrome ct... and a oko 21mm ... as long as you guy's think the quality is there...
Posted: Mon Aug 01, 2011 4:54 pm
by evilone
scottinscotty wrote:and will go with the chrome ct... and a oko 21mm ... as long as you guy's think the quality is there...
Do it.
Posted: Mon Aug 01, 2011 9:53 pm
by scottinscotty
Do i need to buy an new throttle cable? or can i use my stock throttle cable? and i need to buy a new one... where do i get it?
Posted: Mon Aug 01, 2011 9:55 pm
by scottinscotty
and where should i start as far a idle and main jets?
Posted: Mon Aug 01, 2011 10:17 pm
by guen84
21mm carb- 45 pilot 112 main
24mm carb- 50 pilot 120main
28mm carb- 55 pilot 132 main
and your not gonna beat joe with them 8.44's took me 11,000 rpms and a bbk kit to do it!!!
Posted: Thu Aug 04, 2011 6:21 pm
by scottinscotty
What about throttle cable? is it different? and what abou dellorto jets? where should i start if i go with those?
Posted: Tue Aug 16, 2011 3:10 pm
by Petrock's 1984 Spree
Get the 21mm OKO and CT Manifold.
Also get a roller kit of assorted weights for your variator.
And your also going to want to get an idle jet kit and the small main jet kit from treatland as well.
The 21mm works great when you get it going. I've got one on my corsa, so if you do decide to uprgade to a corsa it'll work just as well as it will on your contessa
Posted: Tue Mar 21, 2023 12:18 pm
by veedubh20
Need 28mm pwk carb and center spring 1500. And clutch spring 3000 rpm hit over 70 mph
