So how would I got about doing a plug chop? I checked the wiki spreida but could not find anything. And I fear this soft seize, and would very much would like to avoid it without sacrificing the mod.Trafficjamz wrote:the exhaust is supposed to get hot89eliteR wrote:So I took it for about a 15 min drive and I now notice the exaust heats up quite a bit. Would it not be getting enough air now? It doesn't bog down, nor does it seem to lose any power.![]()
Do a plug chop to tell if you are running lean or rich.
so I decided to get rid of the air box
Re: so I decided to get rid of the air box
- martynkim
New plug run at WOT for about a minute should tell the story. Shut the bike off at WOT.
you missed this. http://hondaspree.net/wiki/index.php5?t ... Plug_Chops89eliteR wrote:So how would I got about doing a plug chop? I checked the wiki spreida but could not find anything. And I fear this soft seize, and would very much would like to avoid it without sacrificing the mod.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
martynkim wrote:New plug run at WOT for about a minute should tell the story. Shut the bike off at WOT.
What would I be observing at that point? I know the spark plug, but would it be burned/discolored?
Thanks that's perfect.dun rite wrote:you missed this. http://hondaspree.net/wiki/index.php5?t ... Plug_Chops89eliteR wrote:So how would I got about doing a plug chop? I checked the wiki spreida but could not find anything. And I fear this soft seize, and would very much would like to avoid it without sacrificing the mod.
So I am attempting that test now with the new plug, but I'm stumped as to what kind of wrench/ socket it is to remove the plug? Any help?
spark plug socket, 13/16 deep well I think. one made for spark plugs have a rubber insert that helps to keep from breaking the ceramic part.
arreche air filter
v8 pipe
stock gears
arreche air filter
v8 pipe
stock gears
The plug chop was done with a new spark plug, and the result is a little bit of oil, very light tan mostly, a little bit of black where the metal part folds over the tit, and a little bit of brown below the space between the tit and the metal part that it goes over.
Here is the finished well working product, thanks again for all the help guys!
- martynkim
Pictures of the plug?
martynkim wrote:Pictures of the plug?
Way too lean still, if you did the plug chop properly.
I used a new plug, held it wide open throttle for 1 min, then cut the engine at wide open throttle. Ill do a second test tomorrow and maybe hold it a little longer? I have been adding extra oil to the gas after i did that test to be on the safe side.Bear45-70 wrote:Way too lean still, if you did the plug chop properly.
you were riding the bike right? not just revving on the stand.
arreche air filter
v8 pipe
stock gears
arreche air filter
v8 pipe
stock gears
no reved it on the stand.dun rite wrote:you were riding the bike right? not just revving on the stand.
