Local Vespa shop installed my 65cc bore kit on 87 elite se50
MySpree
Post by MySpree »
there like a silvery goldish color. i need a new reed seat for mine, but i just quick fixed it with silicone for now....
85spreeelite
Post by 85spreeelite »
Oh ok, I am going to check that out.
Reeds should be closed, with minimal gap (1mm or so is OK.)
If it didn't run before, your carb is the likely problem. I thought it was running before you installed the kit.
85spreeelite
No jayman this one hasnt ran since i got it but the aero is a true runna. So with these rebuild carbs on the was from greg I should puttin around in no time?
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
darat wrote:a hour and a half job?? it only took me a 1/2 to do..
you took off the side skirts,exhaust,shroud and bore. Then installed the new bore. Reinstalled the shroud and exhaust. installed the spark plug and capped it with the coil.Then put backthe side skirts. All that in 1/2 an hour.
85spreeelite
He needs to go on that show Build or Bust on the speed channel.
myhonda
Post by myhonda »
well i pulled my spree apart in a half hour when it died only to find the piston is shot
85spreeelite
Darat? Whats do spiffy about this se bro? Skool a man on that please.
darat
Post by darat »
ok i got lost.. but yeah i took out my whole engine and put it back in in a half hour it is not that hard and i dont have side skirts on it as of now they are in the back of my truck.. i dont like haveing them on..
If the scoot is half pulled apart anyway, changing the jug doesn't take long. I don't even install the sideshields back on mine anymore, as I'm always playing with the engine.
You and Darat both have 65cc kits in your bikes; you two SHOULD be talking about what weights, ramps, and springs to use on that setup once you get it running.
Me, I've got Darat's old '87 Elite powerplant as a basket case in my garage... I should post pics.
85spreeelite
Ahhhh ok I am on the same page now. But you guys remember the spree I got from a kid off creigs list for $50? And took the stock engine off and replaced it with a 87 se elite engine? Well I sent both those carbs to greg for him to rebuild for me, on top of which I bought a rebuilt carb thats on the way. Darat? What size jet are you using on your 65cc hookup? I was told to use a 90 if I am running the stock air filter and run 100 jet if I had a after market filter. And what weight combo are you using?
darat
Post by darat »
i have a 87 on the stock filter.. it runs fine
MySpree
Post by MySpree »
i stole back en egine from a ped in a couple mins includeing takeig the panals and ungoltign the engine!
85spreeelite
65cc scoot still wont run
I got the rebuild carbs from greg and the 87 elite with the 65cc kit STILL wont start. Darat? I sent a PM to you about this, did you read it? Because I really need your help right about now.
darat
Post by darat »
yeah i did get it and well when i got the message it was like 11:30 and i dont think that u want me to call u then so i didnt. u live in michigan right?
