85 spree issues
the0captain
Re: 85 spree issues
Post by the0captain »
Exhaust gasket is replaced and now it syarts right up and idles well but as soon as you give it gas it just wants to die. So what am i over looking?
Re: 85 spree issues
Post by swimmingfree »
i no it sounds like bull but it not
if the lid not on or the tube the goes from the carb to the air box is not clamp on or the air filter is not in or out of place it will do that
in short its going to run len
the0captain
Re: 85 spree issues
swimmingfree wrote:i no it sounds like bull but it not
yes, i've tried all of that. even taped up the airbox to make sure it was sealed.
Re: 85 spree issues
were is the pin on the throttle valve set ?
the0captain
Re: 85 spree issues
swimmingfree wrote:were is the pin on the throttle valve set ?
middle
Re: 85 spree issues
shod be one up from the bottom... i run mine on the bottom
Re: 85 spree issues
as it sit in the carb
the0captain
Re: 85 spree issues
swimmingfree wrote:shod be one up from the bottom... i run mine on the bottom
yup, one up from the bottom is the middle
Mystic
Re: 85 spree issues
Post by Mystic »
hahha swimmingfree........you ran yours on the bottom all right ..........then it puked up its piston :P
Mystic
Re: 85 spree issues
Post by Mystic »
maybe you have a leak around the manifold, taking those carbs on and off cant be good on the orings. I say this because i think mine is leaking there too with the other gaskets. i put some silicon on there this morning waiting for it to set. you might try that if you are out of options :P
Re: 85 spree issues
the faster it gose the faster it gose boooom
my spree by the spedo 32
youe stock spree?
Mystic
Re: 85 spree issues
Post by Mystic »
yup stock figured i would mess with it today while I am waiting on the carb rebuild kit and exhaust gasket for the Eve :D when i break the eve in i may sell the stock spree to this lady police officer that told me she wanted to buyy it for her daughter cause she had one when she was a kid :P
Re: 85 spree issues
hay when you sell it dose it come with a case of duck tape and a spool of balling wire .. you do no that they will need it :lol:
Re: 85 spree issues
Not all needles have five notches, some only have 3.
Re: 85 spree issues
is that by year ?? or by the midrange jet.. i think that what it is???
