Page 2 of 3
Re: Why does this keep happening!!!
Posted: Sat Aug 20, 2011 12:03 pm
by thegoldensb
Posted: Sun Aug 21, 2011 9:39 am
by swimmingfree
what is the ring end gap...
Posted: Sun Aug 21, 2011 12:15 pm
Posted: Sun Aug 21, 2011 4:02 pm
by thegoldensb
Yeah figured bear would say something like that every post i see from him is bashing other people. Heh cool
I measure .8 of a centimeter i dont have anything to get more accurate with.
Posted: Sun Aug 21, 2011 4:24 pm
by swimmingfree
well i hate to say it but in the book is a mimamum and i think max ring end gap for yous motor.. if it is tight when it gets hot it may get cout in the port that wood be my gess
Posted: Sun Aug 21, 2011 5:15 pm
by Trafficjamz
do you have the head matched to the 48mm bore?
Posted: Sun Aug 21, 2011 5:23 pm
-- re: ring gap --
Spree manual says ring end gap for top and bottom ring is(0.10 to 0.25mm), (0.004 to 0.010 in). Service limit is 0.50mm/0.0197in.
0.8 cm is really large, 0.8mm is over the service limit.
Posted: Sun Aug 21, 2011 5:27 pm
by thegoldensb
Alright well the end gap could be the problem I put them on exactly how the manual said being as careful as I could to not stretch them. I don't have the head matched but I was running two base gaskets which tazland said should have zero issues,
Posted: Sun Aug 21, 2011 5:33 pm
thegoldensb wrote:Yeah figured bear would say something like that every post i see from him is bashing other people. Heh cool
Yeah and stupid lazy dumb asses seem unable to open a manual and READ. The info is there and by just handing the info to them you enable them to continue to be stupid lazy dumb asses, making you part of the problem and not helpful at all. The education system has failed and has produced a generation of worthless lazy cry babies.
Posted: Sun Aug 21, 2011 5:35 pm
by Trafficjamz
thegoldensb wrote:Alright well the end gap could be the problem I put them on exactly how the manual said being as careful as I could to not stretch them. I don't have the head matched but I was running two base gaskets which tazland said should have zero issues,
What is the compression?
What year is your spree?
A 1984/85 head on a 86/87 makes about 150psi
add a 48mm bbk to that and your compression could be through the roof!
High compression engines make alot of heat. Heat expands things (like rings).
Posted: Sun Aug 21, 2011 5:38 pm
Ahh Bear, a little more charm in that...
-- Ring gap --
Pardon my questioning this - are you measuring the gap with the ring in the cyl? 0.8cm would point to maybe the ring is broken.
Posted: Sun Aug 21, 2011 5:52 pm
by Trafficjamz
mousewheels wrote:Yeah and stupid lazy dumb asses seem unable to open a manual and READ.
-- Ring gap --
0.8 cm
I am sure that is not a measurement at all........more like a guess......and a bad one at that.
These are brand new rings, and brand new kits. Why are we even discussing end gap wear limits?
Posted: Sun Aug 21, 2011 6:00 pm
by swimmingfree
i wanted to no..
if the ring end gap is it small it may be what is going on with this spree ..
the photo show ( look like ) it got snag on the port ..
Posted: Sun Aug 21, 2011 6:36 pm
by thegoldensb
The gap is probably that big from pulling them off the piston after it got chunked. And bear what are forums for if we aren't supposed to ask questions?
Posted: Sun Aug 21, 2011 8:31 pm
thegoldensb wrote:The gap is probably that big from pulling them off the piston after it got chunked. And bear what are forums for if we aren't supposed to ask questions?
Forums are for asking question that are NOT written down for any idiot to find in the service manual. Most of these morons have not even downloaded the manual know how to find where the information is much less be able to read it and understand what it says. Case in point, half these dunder heads think the number listed at the front of the carb section for the idle mixture screw is where you set it and leave it. They have not bother to read what the manual tells them to do to set it properly. And of course have of them end up with idle problems and off idle stumbles. So
is very applicable and needs to be said.
