Delete
CAPT
Re: 98cc Full Stroker finished
Post by CAPT »
Delete
CAPT
Post by CAPT »
Delete
maddog
Post by maddog »
pink slip your sorry * :crazy:
maddog
Post by maddog »
How did my post go from scooter builds to performance? what dumb * runs this forum :naughty:
niftyman
Post by niftyman »
What???
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
Nevermind maddog.....he likes to troll
CAPT- any updates on this stroker build?
Did you get that tach? what rpms are you turning?
Majourlittle
Post by Majourlittle »
I'd also like to bump this thread. I am interested in hearing more about the actual build as well as where you are on tuning.
deuce217
Post by deuce217 »
Majourlittle wrote:I'd also like to bump this thread. I am interested in hearing more about the actual build as well as where you are on tuning.
x2 please go into some detail on your build.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
CAPT
Post by CAPT »
Delete
scottinscotty
Post by scottinscotty »
Traffic Jamz.... are you intrested in selling that cracked v8 pipe? i am pretty crafty with a welder :naughty:
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
maddog wrote:How did my post go from scooter builds to performance? what dumb * runs this forum :naughty:
The only dumb * here is you and a few noobes who want to know it all like you.
scottinscotty wrote:Traffic Jamz.... are you intrested in selling that cracked v8 pipe? i am pretty crafty with a welder :naughty:
I already welded it back together myself :wink:
I do have a couple other pipes that you might be able to use. PM me If you are interested.
atomicareprise
Post by atomicareprise »
im using a oko 28mm carbs for my 102cc..
now i upgraded to a 125+cc..
what can u recommend should i use for my MJ and PJ for my 28.. carbs..
i'll be running this on 400m
PINOY SCOOTERISTA!!!
sum-azn-kid
Post by sum-azn-kid »
you can get a hold of a fabrizi kit cheaper than a taiwan stroker?
zuma 125-sold
Ninja 250r-totaled
