New 21mm Oko Carb setup help
spewya
Re: New 21mm Oko Carb setup help
Post by spewya »
i will ask him .. all of the carbs should come with a vacume nipple and the fuel nipple?? right
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
spewya wrote:i will ask him .. all of the carbs should come with a vacume nipple and the fuel nipple?? right
No, some carbs come without a vacuum nipple. In fact from my experience most carbs do NOT come with a vacuum nipple.
spewya
Post by spewya »
what i ment was does taz 21mm intake manifold have a vacume nipple
spewya wrote:what i ment was does taz 21mm intake manifold have a vacume nipple
Taz's intake is a CT manifold,,,it only has one nipple and it is for vacuum.
spewya
Post by spewya »
so i will have to tap one in if i want to use the sprees oiler system?
what is better to run the oil pump and premix or to run just premix?
