82cc Big Bore Tuning Difficulties
Re: 82cc Big Bore Tuning Difficulties
Throttle-Jockey wrote:Plug is dark, it's running rich, I'm buying new jets tomorrow. Down sizing the 52 pilot to a 50, will also buy a 48 and maybe a 46. what mains should i try?
I would leave the main alone unless it is 4stroking or bogging at WOT.
Your top speed and acceleration issues have more to do with trans tuning than engine power. :imo:
Mystic
Post by Mystic »
I would think you would want heavier weights in the variator to increase top speed instead of the light ones you have now
Mystic wrote:I would think you would want heavier weights in the variator to increase top speed instead of the light ones you have now
Hard to say for sure without a tach.
Too heavy rollers will not let the engine rev up to peak power rpm's
too light and the variator may not push the belt all the way out.
You can do a simple test for that, by drawing sharpie marker lines on your variator.
Mystic
Post by Mystic »
that is a good idea Tjamz :D I may do that myself in order to get the perfect combo for my weights once I get around to fine tuning it.
808BMW
Post by 808BMW »
28 is usually overkill, but seeing as 95% of modified elites in hawaii use an OKO 28mm carb, it really isn't the limiting factor. That said, I have a 24mm carb on my 50mm bore.
I've never liked v8 pipes for top speed, once you change out for the PG long, I'd start looking at some trans tuning. stock clutch+springs suck :P
Post by swimmingfree »
no good input just doing the small dog thing ..marking this spot :worship:
this has grate in put..
guen84
Post by guen84 »
if your getting a pg long i wouldnt worry to much about tunning right now cause you willl just be starting over when you put the pg on.... pg long made a huge difference for me, was like starting from scratch...
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
CAPT
Post by CAPT »
Delete
kingkamehameha
Post by kingkamehameha »
Your needle clip also needs to be part of your tuning equation. Since your using a bigger bore I wouldn't go lower tthan 52 pilot 138 main. Read up ona proper plug chop
Throttle-Jockey
Post by Throttle-Jockey »
Lots of great advice, thank you all so much for your time and consideration. I just made a couple sandwiches and some ice tea and now its a full day of just me and the bike. Wish me luck. lol.
I did throw the 50 pilot on and its not loading up at a standstill anymore.
I'm about to mess with some tuning and see what i get on top speed.
Thanks again, i'll be on most of the day so i'll let you know.
2001 Honda Elite SR 50
OKO 82cc 50mm Big Bore Kit
OKO 28mm Carb
135 Main / 58 Pilot
DDX/OKO Hi-Speed Pulley Kit
8:44 to 1 Gear Ratio
PG Typhoon V8 Exhaust
Stock Clutch and Springs
OKO 270mm Adjustable Shock
Smoked Out Tail and Turn Lights Assembly
CAPT wrote:You will have better luck with the PG long and the 28mm... Seems a bit strange that you have a black plug with that main jet, I assume the carb is new, so float height is probably not the problem..
I agree with CAPT on that.......does your 28mm OKO have the power jet hose blocked off?
If not .....it should be. That would cause a over rich condition.
PimpinSpree
Post by PimpinSpree »
From what I understand that carb is massively oversized. Whether that actually hurts performance, I don't know. Have you done a plug chop at various speeds?
evilone
Post by evilone »
Trafficjamz wrote:does your 28mm OKO have the power jet hose blocked off?
Did OKO made a 28mm carb with the power jet?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Mystic
Post by Mystic »
they are making all of them with a powerjet now instead of k-101 they are k-102 model OKOs
evilone
Post by evilone »
Are they making both models or is the k-102 replacing the k-101?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
