Tyler VR
Posts: 582 Joined: Tue Sep 27, 2011 12:38 pm
Post
by Tyler VR » Sun Oct 09, 2011 5:05 pm
Posts: 9244 Joined: Mon Jul 23, 1973 10:24 am
Post
by Bear45-70 » Sun Oct 09, 2011 5:07 pm
That Spree front brake is not up to hauling that thing down from 50+ mph in a hurry.
Mystic
Posts: 2140 Joined: Sat May 14, 2011 8:56 pm
Post
by Mystic » Sun Oct 09, 2011 9:10 pm
Looks good
Now its time to work on the fork swap
PimpinSpree
Posts: 691 Joined: Thu Apr 19, 2007 6:40 pm
Post
by PimpinSpree » Sun Oct 09, 2011 10:29 pm
How much does that setup weigh over stock?
deuce217
Posts: 969 Joined: Thu Jun 10, 2010 4:13 am
Post
by deuce217 » Mon Oct 10, 2011 2:18 am
Nice work! Thanks for sharing!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
PolarIce
Posts: 243 Joined: Mon Oct 18, 2010 3:42 pm
Post
by PolarIce » Mon Oct 10, 2011 2:42 pm
Ummmm YES officer that IS the stock motor for this model.
fastplastic
Posts: 1085 Joined: Tue May 11, 2010 7:37 pm
Post
by fastplastic » Tue Oct 11, 2011 12:14 am
Bear45-70 wrote: That Spree front brake is not up to hauling that thing down from 50+ mph in a hurry.
it will but holy brake fade!lol
Tyler VR
Post
by Tyler VR » Sun Oct 16, 2011 12:17 am
Aero forks with spree shaft welded on.
Mystic
Post
by Mystic » Sun Oct 16, 2011 1:05 am
looks good
Tyler VR
Post
by Tyler VR » Sun Oct 16, 2011 9:12 pm
lilredspree
Posts: 180 Joined: Fri Nov 27, 2009 3:28 am
Post
by lilredspree » Sun Oct 16, 2011 10:53 pm
I'm diggin the front end swap. Looks great. My only suggestion would be to round the cut you made on the bottom side front of the fender.
Tyler VR
Post
by Tyler VR » Sun Oct 23, 2011 8:14 pm
Post
by Bear45-70 » Sun Oct 23, 2011 8:28 pm
Performance?
Posts: 4816 Joined: Wed Dec 29, 2010 10:58 pm
Post
by motormike » Sun Oct 23, 2011 8:57 pm
....gaaawwwwddd Bear, you know this puppy will peel your eyelids back....hope he took the speedo cable off and pitched it....TOTAL props to you, Tyler VR....this appeals to me more than any dio swap could....that front fender seems to be shifting around a little, but like the cut....it's a brute.........
zuphilius
Posts: 722 Joined: Sat May 08, 2010 3:23 pm
Post
by zuphilius » Mon Oct 24, 2011 9:51 pm
Remove the fender. Like the GTI also!
