MONSTER Spree
Re: MONSTER Spree
SpreeMadness520 wrote:Where do I get the big black intake? What would be the best carb for my set up?
??? I got mine from a member here.
Ben got one from Darrin.
Maybe you should call Albert.
tru72
Re: MONSTER Spree
Post by tru72 »
im pretty sure i can those those big intake for about 125 shipped..
let me know if you need stuff, jus pm me
aloha
D
SpreeMadness520
Re: MONSTER Spree
Post by SpreeMadness520 »
What gears are gonna be the best? I have 8'4s right now
130cc Stroker
1984 Porsche 944
1965 Vespa
Re: MONSTER Spree
SpreeMadness520 wrote:What gears are gonna be the best? I have 8'4s right now
Your fastest 60 ft time was on 7.5: gears........so I would guess somewhere around there
Mystic
Re: MONSTER Spree
Post by Mystic »
Here ya go I knew you said you wanted one, they just put these on ebay today. The big black CT mani
http://cgi.ebay.com/ebaymotors/Big-Blac ... 3a6b6c40a8
Re: MONSTER Spree
At $100 a pop they can keep them.
Re: MONSTER Spree
Bear45-70 wrote:At $100 a pop they can keep them.
That is how much the BIG black costs.
This is the one you have Bear
http://www.ebay.com/itm/Black-CT-Intake ... 729wt_1181
This one is a lot smaller
Re: MONSTER Spree
Actually no, mine also has the small carb adapter, which is not worth $40.
Re: MONSTER Spree
Bear45-70 wrote:Actually no, mine also has the small carb adapter, which is not worth $40.
The big black is bigger all the way.
The reed cage is bigger, and the bottom section is so big that two of the bolt have to mount from underneath.
It is hard to tell unless you have both in front of you.
Majourlittle
Re: MONSTER Spree
Post by Majourlittle »
So what is the difference between the two different big CT? does the expensive one have a bigger diameter intake elbow?
EDIT: whops, got ninja'd. Better question. Is the BIG worth the extra $50 on a 100cc build? Is it too big?
Re: MONSTER Spree
Majourlittle wrote:So what is the difference between the two different big CT? does the expensive one have a bigger diameter intake elbow?
The CT chrome and CT black have the same lower half, and reeds.
I do not know the diameter of the top half of a CT black.......I don't have one.....yet. :wink:
The top and bottom of the BIG CT black Is bigger than the others. The reeds are much larger too.
Re: MONSTER Spree
Majourlittle wrote: Better question. Is the BIG worth the extra $50 on a 100cc build? Is it too big?
The difference will only be noticed at the drag strip.
:imo: I think it is worth it.....You cant fit vforce reeds in the smaller ct black :wink:
atomicareprise
Re: MONSTER Spree
Post by atomicareprise »
if u can find a koso intake go for it..
koso is bigger than ct...i'm using ct right now but not the black one...
PINOY SCOOTERISTA!!!
Re: MONSTER Spree
Reed comparison for my Black and one of my regular CT.
The Black has a single monster petal on each side of the "V" while the regular CT has 2 petals on each side with a divider in the middle of the reed block.
atomicareprise
Re: MONSTER Spree
we replaced the stock reeds on my ct mani with a cf reeds...
polini is a great buy for cf reeds...
